My first Bonneville
New to the forum? Introduce yourself here. Been around awhile? Tell us about yourself.
GoldPan
Year and Trim: 2003 se
My first Bonneville
Post by GoldPan »
This is what I found on Craigslist, 2003 Bonneville SE just over 120k miles. I got her just over a month ago for $2200.
This picture was taken about 10 minutes after I bought her.
Her she is a month later. I haven't done much to her yet. I did an oil change, replaced a front hub assembly, and I started to polish the headlights..
2003 Pontiac Bonneville SE
Re: My first Bonniville
Welcome!!! Looks good!!!
Bing
Year and Trim: S
Re: My first Bonneville
Post by Bing »
Welcome to the club, lots of good info here to keep your bonne running in tip top shape. :banana:
SSEiMan01
Post by SSEiMan01 »
Not bad!
Welcome to the club!
James May wrote:Hello.
Looking good! Nice job with those head lights!
Welcome to the club. :)
yonkerse
Post by yonkerse »
Welcome to the club! Look forward to seeing the car around for years to come!
Eric
2005 SLE, Greystone Metallic, 152K.
A few mods..
38kronik00
Post by 38kronik00 »
Welcome to the club. Lots to learn here whether it be keeping your car running sound or making it into a mustang killer you will find it here.
2002 Bonneville SSEi 4+ years ownership 103xxx miles.
SD Headers self coated with ceramic header spray, Highflow CAT, Magnaflow muffler in place of resonator, Super 44 Mufflers, Solid Front Mount, Autolite 104's, Rear Spring Assists, Transgo Shift Kit, Intense PCM. My car is NHL certified :P
Mad Myche
Year and Trim: 1999 Bonneville SE
Post by Mad Myche »
Looks nice
~Mad Myche from Around Milwaukee~ wrote:Contrary to what some may think... I have not lost touch with reality, rather; reality cannot keep up with me
1oldman
Post by 1oldman »
Great find especially at that price. Looks like you've done a really good job of cleaning things up. Here are some tings that might help you care for your car, in case you haven't located them yet. I suggest 00Beast's list first. - BC
Care and feeding:
viewforum.php?f=45
00Beast’s suggested list of things to do:
viewtopic.php?f=19&t=26860&p=270794&hilit=list#p270794
1987-2005 Bonneville / Buick 3800 Maintenance List
Run Seafoam, Chevron Techron or Gumout Regane through gasoline every 5,000 miles.
Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease or Amsoil Grease recommended)
PCV Valve Every 30k
Fuel Filter Every 15-25k (Purolator, AC Delco, WIX) http://www.pontiacbonnevilleclub.com/fo ... 45&t=23215
Spark Plugs Every 30-50k (NGK TR55, AC Delco 41-101 or Autolite 605) (Never Bosch)
Oil & Filter Every 5-6k or Every 6 months (Valvoline SYNPower, Pennzoil Platinum, or Amsoil )(Mobil1, Purolator PureONE, Amsoil EaO, K&N or WIX) (Never Fram) viewtopic.php?f=45&t=214
*Conventional Oil Every 3k/3 months(API SM/SN rating) (WIX (Napa), Delco or Purolator filter)
Tires: Check Inflation Pressure & Visually Inspect Monthly Rotate Every 6-8,000 Miles
Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) viewtopic.php?f=45&t=10193
Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Mixes-With-Any Coolant Only) (Never Dexcool)
Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only) viewtopic.php?f=45&t=13626
Brake Fluid Flush 3yr/50k
Power Steering Fluid Replacement/Flush Every 100k or 5 years
*Special Considerations*
All Series II/III 3800's RPO's: L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
[/b]Series II, Naturally Aspirated, RPO:L36:[/b]
7/9/11 by 00Beast
GoldPan
Post by GoldPan »
Thank you, I have a long list of what I want to do to her. Money is holding me back right now. When I sell my truck (1987 GMC 3500 454 FI) (http://i1232.photobucket.com/albums/ff3 ... /truck.jpg) most of the money will go to the Bonneville. I did notice a coolant smell, looks like upper intake behind the TB, will fix a.s.a.p.
I will start with sorry dad. Here is my dads Bonneville, we've had it for about 12 years it has over 200k miles. It has been a really good car, we have gone on many road trips with it. Some day it will get the needed body work and a paint job.
I had to take this photo today. Both Bonneville's and the American Flag.
He is the 1991 from several years ago.
1oldman
Post by 1oldman »
GoldPan wrote:He is the 1991 from several years ago.
The SSE version of your dad's Bonneville is the one that I fell in love with. Bonnevilles were last "sexy" (IMHO) before that in 1965.
Off topic - When we flew into Portland last fall, driving from the airport to Olympia, WA on I-205 was a 1962 Bonneville 4 door hardtop, light tan/beige. I almost chased the car down, but had to be somewhere before 4pm. It looked almost new. It made me remember why I liked the 1955 through 1967 Pontiacs so much. - BC
2002BonnevilleSE
Year and Trim: 2002 Bonneville SE
Post by 2002BonnevilleSE »
Welcome to the club fellow SE owner.
You'll find this site very helpful for any needs or mods for your Bonneville.
Cadet Blue....Not perfect...But paid for.
K&N Air Filter and Gutted air box. 180 Thermo Cleared Corners More to come.
"Unfortunately there is one thing standing between me and that property: the rightful owners."
- Hedley Lamarr, Blazing Saddles
"One morning I shot an elephant in my pajamas. How he got in my pajamas, I don't know." Capt. Geoffrey T. Spaulding - Groucho Marx - Animal Crackers
Post by Jrs3800 »
the 91 Bonnevilles were the cream of the crop so to speak... the 91's had a lot of the updates structurally and electrically as its 92 plus siblings... The springs, struts, lower control arms among a battery of parts... The engine was more or less an L27 Block, even has the same EV6 stamped on it, but is minus a couple of bolt bosses... Even the frame of the car has the threaded bolt bosses for the torque axis mount that was not used in 91... So there were a lot of updates the 91's had that the 90 didn't have... 91 was the best of the 87-91 run......
I would love a 91 SE .... so few of those were made....lol
