Seafoaming
- Jfridge92
Seafoaming
So I got a can of seafoam just to see what I can clean out of the Buick. I've heard the brake booster is the easiest way to get it into the engine (I'll also be running it in the oil and gas tank) so I think that's the line I'll be using.
However, I'm a little confused on one part. I read somewhere that you pour the seafoam into the BB line slowly, and then when it's just about to the last of the portion being used you pour it really fast so that it stalls the car out. Then you wait about 20 minutes, add it to the gas and oil during the wait, and fire it back up. Let it smoke, then drive it after the smoke goes down a little.
So, the question is am I really supposed to stall it out like I read, or just pour it slowly until the Brake Booster portion of the can is gone?
Thanks,
Joseph
Thanks,
Joseph
Joseph
1999 Infiniti G20T - Sold
Re: Seafoaming
Don't use the Booster line, it's too big of a vacuum leak, it almost kills the engine. Use one of the smaller lines.
Yes, you need to kill the engine once you are done. You let the line suck the seafoam in, not pour it in. Get a plastic cup to pour the seafoam in then let the line suck it out. You then stall the engine and let it sit for a while for it to penetrate into the carbon built up on the pistons, etc. Then do the smoke-show.
- wdudetocool
- SSEi Member
- Year and Trim: 2000 se
- Boreas
- Posts like an L36
- Year and Trim: 1993 SE
1996 SSEi
1997 SSEi 40th - Location: Chi-Town
Re: Seafoaming
Do it out where there isn't a lot of people, or inform your neighbors in advance if they have a twitchy 911 finger.
1993 Bonneville SE "Old Ironsides" 244,xxx - Junked.
1996 Bonneville SSEi "Double Trouble" 164,xxx - Stock
1997 Bonneville SSEi 40th "Purple Spaceship" 204,xxx - Aeroforce Interceptor, B&M 70264 Trans Cooler, Intense FWI, High-Flow Feline, non-Bose head unit w/ 5 band, Alpine 6x9's, 3.5 MPS, SD Headers, rear disc brake conversion. Future: 1.9 Rockers
1997 Buick Park Avenue "Blue Floaty Thing" 124,000 - Daily Driver/Winter Beater
swampthing
Re: Seafoaming
I usually use the booster line as well due to its ease of removal and the fact it doesn't crack or anything. I just take my thumb and cover about half the hole and tip the can and allow the suction to do the rest, if it starts to stall I cover the hole completely til it catches up.
A word of caution on using it in the oil, due to its detergent properties its only recommended to put it in if you are planning on changing the oil the same day, otherwise bad things could happen
Current fleet:
Current fleet:
93 SSE 4 ME
- Year and Trim: 2005 SLE
Re: Seafoaming
Just insert a smaller diameter piece of vacuum tubing into the booster line and seal it with some tape. I don't 'pour' the Seafoam into the vac line, I actually let the vacuum draw it in in quick dips into the Seafoam. After half a can, I let the line drown in it, which kills the engine. Let the car sit ~10 minutes before you restart it and enjoy the smoke show. The link below is very informative. http://forums.turbobricks.com/showthread.php?t=35053
Mark
Mark
'05 Bonneville SLE Intense FWI & PCM, Wood Dash Kit, Chrome Valve Stem Caps!
'14 Silverado LTZ
'08 Acura TL
'05 VW Passat GLS
'14 Silverado LTZ
'08 Acura TL
'05 VW Passat GLS
swampthing
Re: Seafoaming
Forgot I had a can laying around and decided to do my Bonneville today, very interesting results but I will post in my own thread about that
Current fleet:
Current fleet:
Re: Seafoaming
I thought that doing it through the vacuum or intake tract will trash a O2 sensor in a fast hurry.
Re: Seafoaming
It can, yes.
I also concur, don't leave it in the oil. Pour some in, drive 100 miles or so, then change the oil.
- Jfridge92
Re: Seafoaming
An oil change will be following it almost immediately, I'm just about due for one anyway.
And a new O2 sensor is in need as well, it still has the original on it at 115,xxx mi
Edit: Add a new starter to that list
Ed, which vac line do you recommend using if not the brake booster? I know there are other smaller ones, but ones like the FPR line or which will be the best in your opinion?
Joseph
Re: Seafoaming
I would use the one coming from the TB to the EVAP system.
Re: Seafoaming
I thought I would bring up the O2 sensor for others that are lurking the post, so all the info is out there for them.
- Jfridge92
Re: Seafoaming
It's a good thing to know, Bing, as I wouldn't have thought to change it afterwards. But now I know haha.
Joseph
- wake
Re: Seafoaming
dont forget to check that fuel filter and pull a spark plug or two while your at it..
regular maintenance and what not
38kronik00
- SSEi Member
- Year and Trim: 2002 SSEi
Re: Seafoaming
93 SSE 4 ME wrote: http://forums.turbobricks.com/showthread.php?t=35053 Mark
2002 Bonneville SSEi 4+ years ownership 103xxx miles.
SD Headers self coated with ceramic header spray, Highflow CAT, Magnaflow muffler in place of resonator, Super 44 Mufflers, Solid Front Mount, Autolite 104's, Rear Spring Assists, Transgo Shift Kit, Intense PCM. My car is NHL certified
Re: Seafoaming
By the time it hits your pistons it's steam, and it blows the carbon off. It's been around for a long time.
- Jfridge92
Re: Seafoaming
Lucas, the fuel filter and plugs are practically new (did the plugs roughly 7k ago with the intake) and the fuel filter a few weeks back
But yes, good maintenance habits are a must!
Thanks for all the suggestions so far guys!
PS, anyone know a good source for the gear reduced starters? None of the bone yards have any around me, and I figured I'd ask first before I drop 100+ on one from Rockauto...
Joseph
Re: Seafoaming
Haro?
- Jfridge92
Re: Seafoaming
PM is sent, but I figured I'd ask in case he doesn't have any, but with the selection he's got I'd assume he probably does haha.
Edit* starter is ordered from Andrew, so it looks like I have some fun projects coming up!
Joseph
Mad Myche
- GXP Member
- Year and Trim: 1999 Bonneville SE
Re: Seafoaming
If you've ever watched cooking shows, after they have seared something in a pan they will 'de-glaze' the pan with water or other low boiling point liquids. The water instantly vaporizes on contact and brings the 'flavor" deposits into suspension.38kronik00 wrote:Water?? I would never have thought to use water...WHY WATER lol
Very similar to water into the intake; it removes the deposits as it contacts the back of the intake valves.
~Mad Myche from Around Milwaukee~ wrote:Contrary to what some may think... I have not lost touch with reality, rather; reality cannot keep up with me
