3.8 Noise... Timing Chain/Dampener? (Hopefully!)
DieselMechanic
Year and Trim: 1998 Bonneville SE. Green, Gold Crosslaces
Post by DieselMechanic »
The Bonneville was Duramax powered for a while today. :sad:
I thought I might have heard a slight noise a while back while under the hood of my car down around the water pump area, but kinda disregarded it.
Yesterday morning after a pretty harsh WOT pass, I turned into a gas station a few miles later and heard a terrible knocking noise, so I immediately shut it off and hauled it home on the gooseneck this morning.
Oil pressure is perfect at idle and there is no miss to it, started perfect.
I did notice today when I started it to pull it onto the trailer, the noise was nonexistent exept for a "loose rattle" noise right at startup, if that makes any sense. Then after it ran about 30 seconds or so, I could barely hear it beginning to make noise again just before I shut it off.
Sounds as if it's coming from the front/center of the engine. This sound like a timing chain or a dampener guide?
I'm sure I'll be able to figure it out, but honestly never worked on a "sideways" or fwd vehicle before. Hell, this is the first car I've ever owned in my 30 years. LOL Always had trucks.
Any tips to tearing into that area?
Also wondering, if I end up replacing it altogether, would it be easier to drop the entire K-member with tranny and all? Or to pull it from above?
I've got a pretty nice place to work on it, and a descent engine hoist.
98 Bonneville SE, 98 GMC Sonoma Highrider, 99 Lincoln Continental, '98 Yamaha Grizzly IRS
Re: 3.8 Noise... Timing Chain/Dampener? (Hopefully!)
First, most important question: Does it only happen at idle?
Sounds like a dead ringer for a bad harmonic balancer.
crappiefisher
Year and Trim: 02 40th Anniversary GTP.
Post by crappiefisher »
2 fast tests...engine off, can you turn the belt system at all? any play either direction makes the balancer suspect.
then, remove the belt from the crank pulley, secure it out of the way and start the engine for a few seconds, is it quiet now?
A bad balancer sets up quite a racket, and replacement is the cure :)
DieselMechanic
00Beast wrote:First, most important question: Does it only happen at idle?
Hmm honestly, I'm not sure... IIRC, I think I gave it a little gas and the noise was light along with it. I will have to check it out tomorrow.
crappiefisher wrote:2 fast tests...engine off, can you turn the belt system at all? any play either direction makes the balancer suspect.
I haven't tried turning the belt system... I did remove the belt and start it, however. Noise is still there.
God I hope it's a balancer... This is the worst time possible for this thing to take a crap on me! lol
Last edited by DieselMechanic on Sun Dec 18, 2011 6:53 pm, edited 1 time in total.
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
If the rubber is gone, it can rattle without the belt on at idle too. It's been a while, but I think mine did.
willwren
Post by willwren »
It will clatter with or without the belt if it's the dampener (harmonic balancer/dampener). But it will shut up for a few seconds if you lightly roll into the throttle.
