Digital Torque Wrench - Holiday Special
This is a Vendor only forum specifically made for BC Vendor specials and to answer questions about products. Only approved/authorized vendors are allowed to post goods and services here.
If you want to be a recognized vendor on this Forum, send a private message to an Admin.
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Post by blmw »
Extended until January 31st
Brown Line Metalworks is a manufacturer of Digital Torque Wrenches. We thought they would be of interest to members of this forum, so we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: bonneville
You can see the torque wrench in action in the following video:
Brown Line Torque Wrench In Action
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid till October 15th, and is only for the lower 48 states. Extended until January 31st
willwren
Re: Digital Torque Wrench - Special
Post by willwren »
Welcome aboard! That's a great tool with a great price, if I needed another, I'd look at this one. Personally, I think if you made that a swivel head, it would be a big hit in the automotive market. Swivel heads are great for torquing headers or exhaust manifolds, especially on the rear bank of a front wheel drive motor.
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Post by blmw »
willwren wrote:Welcome aboard! That's a great tool with a great price, if I needed another, I'd look at this one. Personally, I think if you made that a swivel head, it would be a big hit in the automotive market. Swivel heads are great for torquing headers or exhaust manifolds, especially on the rear bank of a front wheel drive motor.
Thanks for the welcome, and the suggestion. It is something I will look into, but the problem with the swivel head is that the accuracy gets thrown off when the swivel feature is used. This also applies to a "flex head" torque wrench - the wrench is calibrated with the head not being flexed. When it is flexed, the wrench will loose accuracy.
BLMW
2001SSEi
Year and Trim: 2001 SSEi
Post by 2001SSEi »
I would like to ask about one more suggestion. Is it possible to add torque angle to an electronic torque wrench like your?
thanks for the introductory offer...
Mike
2001 SSEi 133,000, Intense FWI, ZZP SS Headers, S1X Cam, ZZP Aluminium Heads, 3.2 Intense, GenV, 180 Stat, 42#, WB O2 LC1, HP Tuner Pro, ZZP tranmission.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
What kind of warranty do you offer? Can we send it back to you for calibration?
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Post by blmw »
2001SSEi wrote:I would like to ask about one more suggestion. Is it possible to add torque angle to an electronic torque wrench like your?
Mike
Mike:
It is something we are in the process of working on, but realistically will not be ready till late next year.
BLMW
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Post by blmw »
01bonneSC wrote:What kind of warranty do you offer? Can we send it back to you for calibration?
Our warranty is industry standard: 1 year from date of purchase, 90 days for calibration. We have a repair/calibration facility in Chicago in case anything ever does need to be done to the wrench.
BLMW
No offense to the OP, but shouldn't you be registered as a supporting vendor to sell things? PM willwren or another admin for more info.
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Post by blmw »
00Beast wrote:No offense to the OP, but shouldn't you be registered as a supporting vendor to sell things? PM willwren or another admin for more info.
I spoke to Will before I posted anything and got the okay. He was the first person to comment on the thread.
BLMW
01bonneSC
89 SkiDoo
Post by 01bonneSC »
Bill did say 'Welcome aboard'....
willwren
Post by willwren »
I haven't had time to jump in and change his rank. Next time it's best to PM an Admin before posting like this. I'll fix his rank shortly.
(Please note in the first reply to this topic by ME.......as pointed out.......WELCOME ABOARD)
Got it. Thanks Bill, just wanted to double check.
If I needed another torque wrench, I'd definitely be looking at this one. However, the torque angle feature would definitely be a BIG seller, especially for these cars.
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Post by blmw »
First, I want to thank everyone for the response to our product. Second, we have gotten some requests to extend the sale through the upcoming Holidays - so we will keep the special going until 12/31.
Thanks again.
BLMW
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Re: Digital Torque Wrench - Holiday Special
Post by blmw »
Just a reminder that time is running out!
willwren
Post by willwren »
Somehow Mrs. Claus pulled one of these off for Christmas with a little help from some Elf (Gearhead) that lives very close to me (myfirstbonnie) and likes Fried Chicken (drives a rubber chicken). Rumor has it that he got one too.
VERY impressive. This thing just replaced 3 of 5 torque wrenches I own. The only exceptions are my inch/lb wrench and my swivel-head for exhaust manifolds. The three it replaced are for one very simple reason:
You can't get a mechanical clicker torque wrench that can be accurate in this broad range, from 15-150 ft/lbs. It's simply not possible. But with a digital load cell, you CAN. Coolest Christmas gift of the year by far. Batteries going in today, then some playing around with it to figure out all the features.
Yup, got one too. I had to check the torque on my Chicken nuts to try it out.
I am actually impressed with this and glad I got one. Highly suggested for anyone looking for a torque wrench.
willwren
Post by willwren »
After playing around with it, I have to say you can't get a better tool for the price. I already owned 5 different torque wrenches and have another dozen or so at work, and this one beats them ALL. If you have to buy one, this one will do it all very well. It'll do everything from the low-torque (20 for supercharger bolts or 25 for re-usable rocker bolts) all the way up and beyond wheel lug nuts. You can't buy a mechanical torque wrench that will be this accurate and effect at both extreme ends of the scale.
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Post by blmw »
We have gotten a number of requests from members who missed the deadline, so we are going to extend this special until January 31st. Thanks for the orders and support.
BLMW
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Post by blmw »
One week left.
blmw
Recognized Vendor
Recognized Vendor
Year and Trim: na
Post by blmw »
1 Day Left !!
