Can you identify this car?
viper8907
Post by viper8907 »
A friend of a friend posted these pictures on facebook of her car. Supposedly she had smoke coming from the hood, pulled over, popped the hood and it was on fire. Most certainly a UIM failure I'd say. Can you guess what it is? I didn't know at first, but I think I got it figured out.
-Tom
2003 Silverado Ext. Cab - Charcoal - 128,000 miles - Stock...for now.
2000 SSEi - Gone, but not forgotten.
PLAGUE PHANTOM
Year and Trim: 1968 Chevrolet Bel Air
Re: Can you identify this car?
Post by PLAGUE PHANTOM »
2000-2005 Buick LeSabre
1997 Bonneville SLE...(SilverStreak)...Totaled...1/25/13...Gone but not forgotten.
1968 Chevrolet Bel Air....the project
94SilverSSEi
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Post by 94SilverSSEi »
PLAGUE PHANTOM wrote:2000-2005 Buick LeSabre
x 2
1st pic I thought it was a 98-05 Park Ave but the next couple pics gave it away.
But wow that was a terrible fire. So did your friend just get away from the car when it was on fire or what happened there?
Sidenote: Not sure if anyone watches Hardcore PAWN, but on there a guys Impala started on fire. (Is it bad I knew exactly what caused it right away...lol)
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
BlackHawk99
Senior Moderator
Senior Moderator
Year and Trim: _
Post by BlackHawk99 »
That wasn't from the UIM. There's no way.
It was likely from a bad fuel pressure regulator. Very common failure point on the L36. Same can be said for that one on Hardcore Pawn too. (I saw that episode earlier in the summer)
2012 Ford Fusion SEL, 2012 Chrysler Town & Country, 2007 Chevy Silverado LT, 1999 Pontiac Firehawk, 1979 Pontiac Trans Am
Post by Jrs3800 »
The UIM's with the regulator issue is a problem when you start the car, have a slight backfire through the intake and BOOM...
I bet my money on the fuel line was leaking and sparked a fire under the hood... Very common fuel leak is the pressure fitting, over time the movement of the engine wears out the O rings and the fuel dribbles out onto a hot engine...
Sad to see the car burn to the ground tho...
BlackHawk99
Senior Moderator
Senior Moderator
Year and Trim: _
Ya, I should have been more clear like you Don. lol. Based on classic signs of a UIM just leaking coolant, there's no way it would have caused a fire like that.
Bonneville92V688
Year and Trim: ‘12 Jeep Grand Cherokee Overland Summit
Post by Bonneville92V688 »
Wow.
I'm starting to see why GM dumped the plastic lines/fittings under the hood and updated them to metal fuel lines on later cars. The '11 Impala has metal fittings with crimped rubber lines as seen Here. They turn to plastic under the car.
1996 Thunderbird LX - 3.8
yonkerse
Post by yonkerse »
That was one heck of a fire! Very sad to see a 3800 go down like this :( Another reason its good we check over our cars every now and then...just to ensure nothing is leaking or acting differently than expected!
Eric
2005 SLE, Greystone Metallic, 152K.
A few mods..
Post by Jrs3800 »
Agreed... I have had to replace the fitting on my 95 some time ago... I will replace the length of line in the near future... I have also had to replace the same section on my 03, it had developed that same leak...
human
Year and Trim: Daily Driver: 2011 Impala LT
Weekender: '95 Aurora
Post by human »
I know what that car is. It's a total loss!!!
Weekend Toy: 1995 Olds Aurora
For sure a 00+ LeSabre.
Sucks to see that. If she hadn't have popped the hood, she could've probably gotten her stuff out before the whole car went up... (added more air to the fire)
vogie01
Post by vogie01 »
Looks like a 97-04 Regal to me. The body does not seem long enough to be a LeSabre.
At least she was on a dirt road!!
Definately a Lesabre. The dead give-aways are the wheels, and the front bumper and radiator support (identical to the H-body Bonneville).
Bonneville92V688
The rear struts give it away that it's a LeSabre. W-bodies have coilover struts in the back.
SSEiMan01
Post by SSEiMan01 »
vogie01 wrote:Looks like a 97-04 Regal to me. The body does not seem long enough to be a LeSabre.
Those wheels scream Lesabre, plus the gas door is round and directly above the wheel, also LeSabre. Regals have more of a square gas door that's a touch farther back from the wheel. ;)
James May wrote:Hello.
That is undeniably a LeSabre, no question about it.
LeSabre:
Regal:
Look at the back door. The Regal has a triangle quarter window, the LeSabre has the rounded corner towards the back. No Question.
viper8907
Post by viper8907 »
I guess I always thought that engine fires on 3800s were cause by the dread UIM failure! Shows how much I know! haha. Like Andrew said, it screams H-Body. Even whats left of the seat you can tell it's similar to the Bonneville seats (if not the same)
-Tom
GMC Guy
Year and Trim: 1999 Bonneville SSEi
Post by GMC Guy »
wow lots of heat... the last pic there is no rear rim.....
dont worry though....That'll buff right out! No worries!
Tinted 13% Front 3% Rear, MSD Coils and Wires, K&N drop in air and oil filter...more to come as things wear/break!!
Tint it so dark, you won't even know your name
nickdalzell1
Year and Trim: '92 Bonneville SSE
Post by nickdalzell1 »
WOW. i have seen fires before (when hanging at a junkyard you see all kinds, mostly Taurus with the valve cover leak at the back will spark one up very fast, and one Probe caught fire after being allowed to overheat (it was junk with no oil press but kept going anyway) but in those cases they never allowed the entire car to burn. a bit of water or a tiny B-C fire extinguisher did the trick. i had a Caddy limo do that once due to a bad oil leak onto the exhaust and it only burned a few wiring harnesses. usually with burning to the ground the first they see a fire they take off and run. kinda fearful of quick explosions in those movies, usually that doesn't happen till it gets to the rear
1992 Pontiac Bonneville SSE (3800 Series I, 277K miles and counting! with a horrific knock sadly)
That is actually a really sad sight. :sad:
