myfirstbonnie wrote:I think I'll replace this part:
Probably a good idea
That, plus 100k+ of chain stretch is probably worth a few degrees of retarded cam timing.
Only going to get the pan and front cover on tomorrow. A little more work before I get the intake ready.
Filter adapter has to wait until Wednesday when the Intense kit arrives.
Can the S1 and 2 tensioners be retrofitted to LN3?
In both my wife's Bonne, and my brothers Lesabre, the tensioners were about twice as long, no wear, but made of the same plasticy nylon stuff.
Glenn
1999 SLE 70k Stock for now http://www.cardomain.com/memberpage/593472
When I purchased mine I found that the same one fits 87 to 94. They changed the design of the LN3 to match the series 1. The only difference is that on the earlier LN3 there was a change to the bolt hole. It was either chamfered or it was countersunk. The actual damper was the same.
Found another issue that I did not notice while tearing it down. The TB gasket was installed incorrectly. Notice the tab on the stud to the left in this picture there is also an offset of the bores:
This is what it stamped into the gasket:
Now I am not a college grad (yet), but this is not the top, but is the rear of the engine. I tried every way to put it on and there is only one way it lines up with the bore of the TB and the EGR adapter:
Wow.... thats kinda hard to put that gasket on wrong with the labels and the overall fit. I wonder if whoever put it on at the factory (or whoever tore it down last) had a few too many brewskis at that point...
-Eric "Energy and Persistence Conquer all Things"--Benjamin Franklin
-1989 Buick LeSabre T Type: 220k miles
-1987 Fiero GT: 224k miles
-2012 Honda Civic (boring, but its a good DD)
The gasket was actually labelled wrong. The bottom is actually labelled as the top. If you look at the curvature of the stamp it looks like it was stamped upside down. The arrow is pointing to the top of the throttle body.
Slowly getting there. Should have remaining parts ordered this weekend. There are a lot of dried out grommets that I will need to order. The good thing is they are still available. Here is the progress so far:
was the belt tensioner always that clean or did you scrub it up too?
Glenn
I always kept it as clean as I could without removing it, but you would not believe the dirt and grime down in the nether regions. All better now. Here is a before picture. I didn't own it very long when this was taken. As you can see this was before the ignition swap.
Well, after chasing down grommets, I have started the reassembly. Need to finish up the alternator and then the TB and that end. Here are the pictures with the cover on the engine. The fuel rail is already installed underneath.
I did some painting, so feel free to critique it.
Before:
In progress:
And then I must go to work, so assembly is halted until tomorrow.
Well, it is running. Sounds pretty good too. It took a few starts and stops to get the air out of the power steering, but here is a video of the first run to come up to temp. No lights on the dash at all. Here is the video:
Omg! You just made me want to cry with that video..I miss my 89 so much.
That thing sounds brand spanking new! Excellent dead on, quick throttle response and an excellent, even exhaust tone.
Outstanding! Excellent job!
John Now: '15 Toyota Prius III | 134 hp 2ZR-FXE | Silver | 36k
Now: '03 Honda CR-V AWD | Slow 4-Cylinder | Dirt | 180k Then: '07 Ford Fusion SEL | 221hp Gen I VVT Duratec 3.0 V6 | Tungsten Silver | 150k
That whole car is in nice shape for its age. Sounds just like ours here, just looks 10 times better
Nice work!
Glenn
Thanks guys, I wanted to take my time and do it right. The older gen seems to be fading and I want to keep this one going for a long time. Thanks to the northwest I don't have a lot of rust on it.
I think the next thing will be the FE2 suspension parts. Other than that, front tires, brakes all around and then here before long it will need a tranny job.
