Mirror ????
piranhaman77
- Year and Trim: Stock 1995 Bonneville SE ( for now )
Mirror ????
Can anyone recommend nice power side mirrors for my 95 SE?
1995 Bonneville SE Bone Stock........ FOR NOW!!!!!
And to top that off it was a freebie that didn't run.
Told me if I got it the heck out of the yard it was mine.
WOOOOOO HOOOOOO!!!! New starter and its on the road.
Many Mods to come in the future for My LiL Green Monster!
- 99BonnevilleSE
- Posts like an L27
- Year and Trim: 1996 SSEi
Re: Mirror ????
I didn't know you could get non power side mirrors on a 92-99 Bonneville.... But you could always get the mirrors, all the wiring, and the switch from a 92-99 Bonneville with power mirrors from a junkyard and retrofit it.
I'm backkkkkkkkkkkkkkkkk!
Re: Mirror ????
Stock? No one makes aftermarket mirrors. You could use Buick LeSabre mirrors, which don't have the black strip around the inside, but there isn't really anything else.
I'll have your other thread locked.
Re: Mirror ????
As 00beast mentioned, Buick or Olds mirrors are about your only choice for a direct bolt on but will have a slight wiring difference between the connectors.
I just happened to find the Buick mirrors in my color at the junk yard I frequent. When I pulled the mirrors I also took the connectors from the Buick and I found a wrecked set of bonne mirrors to cut the connectors off of. I made a pigtail connector so that I could simply plug into the Buick mirrors and my cars mirror connection.
piranhaman77
Re: Mirror ????
Well I'm not a fan of the small side window on the front doors and where the mirrors are located. So I was wondering if a later model door will fit my 95 model with out the side windows and fit the general body lines even if it would need some modifications.
Re: Mirror ????
No.
Re: Mirror ????
All 92-99 Bonnevilles had that door, and the 00+ door isn't even close. It'd be like trying to fit the door off of a Hummer.
95elite
- Year and Trim: 96 sse, 95 regency elite L67
Re: Mirror ????
does anyone know if side mirrors from a 95 olds regency would fit a 96 bonneville?
- willwren
- Retired Admin
Re: Mirror ????
Most likely.
