Headlight switch wiring
superman013
Year and Trim: 1995 SSEi
Post by superman013 »
my 95 headlight switch/harness melted on the plug. i have a new switch/ harness from 92 both with twilight etc. wire colors are different but wondering if anyone here knows what color wires from the 95 i should connect to what colors on the 92 harness? Thank you in advance
95 Bonnevette SSEi Badgeless New Everything Including Paint, Fully Customized.
willwren
Re: Headlight switch wiring
Post by willwren »
I don't believe you can use the 92 switch. I think you want a 95-97. I would avoid the problematic 95 (it's a known serious problem) and look for a 96/97 switch.
superman013
Yes i think that is exactly what i am going to do i already changed out the 95 2 times im just going to move foward to the 97 and be done with it. Most likely get the parts tomorrow is there any wiring difference i should be aware of?
willwren
Post by willwren »
If you get the switch and the connector from the donor car, wire it by wire location, wire-by-wire, regardless of color. It should be a permanent fix.
human
Year and Trim: Daily Driver: 2011 Impala LT
Weekender: '95 Aurora
Post by human »
I replaced mine last fall with a switch from a '97 and all the wires were the same colors except for one. If you go wire-by-wire, you won't mess up.
Weekend Toy: 1995 Olds Aurora
