p0171 1996 Bonneville
driveway Al
- Year and Trim: 1996 Pontiac Bonneville
Hey guys, my check engine light went off. It was reading the p0171 code. I found a crimped and cracked vacuum line and replaced it. I was ready to take the car back thru state inspection but when I checked the OBD2 with the actron code reader the p0171 code was still there even though the CEL was off. The CEL works because it lights up when I turn key to start car. Anyone have any ideas as to why the code is still there even though light is off?I drive a 1996 3.8L Pontiac Bonneville. Thanks.
Driveway Al
Driveway Al
driveway Al
Re: p0171 1996 Bonneville
not yet, I was hoping the computer would run a drive cycle and delete it. I can erase it myself but i thought the comp. would delete it from memory. This way i woukld know for sure it is ready for inspection. Do you think it may be a stored code. The actron reader does not give you much info. thanks.
Driveway Al
Driveway Al
- Mechanical Mike
- Retired Gearhead
- Year and Trim: 99 SSEi
It may take a few drive cycles before the code disappears. It might still pass as long as the light stays off. If you erase the codes it may take a few days before you can get it inspected.
2006 Chevy Monte Carlo SS
- willwren
- Retired Admin
It's a history code, only a current code will set off the light.
driveway Al
will the history code go away or do I still need to turn off? I am not sure if the state insp. will fail a car for the history code. If I erase history code do you think the car still needs to run another drive cycle after that. I still have another month or so for reinspection. Thanks for the advice.
Driveway Al
Driveway Al
locowbl
- Year and Trim: 2000 SE
The history code will stay there until you delete or erase it but won't come back on if you've fixed the problem.
LocoWBL
- willwren
- Retired Admin
It shouldn't fail you. But erasing a code may.
locowbl
Are the inspections so strict there that they put a code scanner on the vehicle?
LocoWBL
driveway Al
its New Jersey, besides having the highest taxes and most crowded roads they are also a pain in the ass about CEL. No matter what the light is on for they will fail you regardless.
Driveway Al
Driveway Al
locowbl
I certainly don’t want to recommend you do anything that might cause you a problem .
LocoWBL
- Mechanical Mike
- Retired Gearhead
From the FSM:
The PCM will turn the Mil off during the third consecutive trip in which the diagnostic has been run and passed.
The history DTC will clear after 40 consective warm-up cycles have occured without a malfunction.
driveway Al
Thanks, i will erase the history code and wait till sometime next wk and take car for inspection. I doubt their comp. will pick up an erased history code. The car runs graet and i want to keep for awhile. The only other problem is that it can be a gashog. While changing out UIM and LIM I found magnets on the fuel rail. Maybe previous owner thought it might improve gas milage. I took them off and did not put them back on. Can't see how they work or why.
Driveway Al
Driveway Al
