Should I go with 2 or 1?
Two or One?
Poll ended at Tue Aug 09, 2011 12:07 pm
2-
No votes
1-
No votes
Total votes: 0
JG2000SE
Year and Trim: 2000 SE
Post by JG2000SE »
Just wondered if there would be a sound difference or advantage to running 2 mufflers rather than 1? It would be for sound only, not looking for performance.
For sake of argument, lets assume we are comparing the option of 1 Magnaflow with a one inlet/two outlet design versus 2 Magnaflow's with a one inlet/one outlet design. The end result would be dual style exit at the rear of the car like an SSEi.
I've seen this covered on other forums but not here, not directly at least. Not trying to start arguements or flame wars, just looking for opinions and experience. It seems the majority opinion is that 2 can sound better than 1 although it is a little more expensive for the set up. Thanks for any input.
2000 Bonneville SE- Galaxy Silver Metallic - Gutted Air Box - K&N Filter - 20% Tint - 77k miles
JG2000SE
Re: Should I go with 2 or 1?
Post by JG2000SE »
Will it even make a difference if it is not a true dual exhaust and it simply splits behind the rear axle? Just looking for the best mellow, smooth, sound.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
Make sure you keep the cat and resonator for a good sound.
JG2000SE
Post by JG2000SE »
It would be a stock set-up otherwise. I am basically wondering if there would be a difference in going with the F-body style Magnaflow mounted across the back of the car with dual outlets or, two smaller mufflers closer to the back of the car, possibly with tips attached directly to the muffler outlets as I've seen on other cars like the new 2011 Camaro's.
01bonneSC
89 SkiDoo
Post by 01bonneSC »
I think money is the only diff. Two mufflers vs one.
Turbo30
Year and Trim: 2003 SE
Post by Turbo30 »
For not changing performance, I would prefer one muffler with dual outlet, just for the sake of saving a bit of money.
About to go to a guy I know that builds race exhaust systems and see if we can't figure out how to build a true dual exhaust for my SE and see if it will even help anything at all ..
~Shawn
2003 Bonneville SE: Galaxy Silver; 189,XXX; INTENSE FWI; 180° thermostat; Pioneer HU; Kicker ZX350.2; Kicker CVR10; HID conversion kit.
wake
Year and Trim: 96 olds cutlass supreme 4 door
Post by wake »
the polls havent been working lately :bhuh:
i say true duals sounds like a bad arse idea :beerchug:
:headbang:LUCAS Image Member # 534.
96 olds cutlass supreme SL 4 door 3100 4t60 *3.33 gears* *Fe1* 115K bone stock DD
JG2000SE
Post by JG2000SE »
I would love a true dual set up but I don't know if there is enough room. It has been my experience that some of these lower riding GM cars just don't have room underneath.
My main question is, would the dual mufflers affect sound? I was hoping two mufflers would create a type of echoing lower growl. Like maybe two Aerochambers mounted right at the rear with dual tips on each muffler?
Also, lookin for 00beast and willwren and some other well experienced Bonne owners to reply :poke:
Well considering my car has a stock Rez-back idk how much input I should really have in this thread, lol. SSEi's stock split behind the axle from a single 2.5" pipe to 2-2.25" pipes into the mufflers.
You cannot do true duals, the front bank leads into the rear exhaust manifold where the O2 sensor is, and I don't know of a way to add another O2 sensor to the circuit. In any case, true duals would be expensive and not worthwhile for any FWD 3800.
Honestly, your first exhaust mod should be a downpipe and HF cat. After you've done those, give it a few weeks and decide if you want more. I'm in love with my car's exhaust note as it sits with 3" from the rear manifold to the resonator with a High Flow cat and stock resonator back. It sounds more like a quiet V8 at hot idle. If you want more, we can go from there. You'll also gain some power and performance.
01bonneSC
89 SkiDoo
Post by 01bonneSC »
I wouldnt do true duals. Waste of money. And everyone else know my opinion of after market mufflers on anything that has less than 8 cylinders.
If you go with a DP and hi flow cat you will gain some growl as 00Beast stated. A P-Log would help you with flow also.
willwren
Post by willwren »
The amount of money wasted on exhaust going true duals would be ridiculous. Spend your money on something that will actually gain performance.
JG2000SE
Post by JG2000SE »
So, been listening to approximately 100 different sound clips over the last couple weeks and I have come to the conclusion there is almost no difference, or at least I can't really find any, between Flowmaster, Magnaflow, Dynomax, etc. It's just too hard to tell and there are too many differences in set-ups.
Gonna go with one muffler (Jegs has Dynomax mufflers for $26!) with a dual tip to start and see if I like it before going any further I guess. Not looking for performance yet just a little different sound. I'm sick of the stock brown muffler and tail pipe sticking out from under the car, remember I have an SE... :???:
willwren
Post by willwren »
Try a Hooker Aerochamber then. It's a uniquely different sound.
BonneMe
Post by BonneMe »
If you like the dual tip look, find an SLE/SSEi cat back setup, and swap in new mufflers and bolt that in.. Alternatively, you could have a shop put a Y and some pipe off of your stock system like an SLE/SSEi would have. Whichever way is cheaper depends on prices for a used exhaust setup in your area.
willwren
Post by willwren »
Used is a great option, Zaisarooni. Might be a big savings in the long run.
2000Silverbullet
Post by 2000Silverbullet »
I went for twin magnaflows, 3" after the headers into twin 2 1/2".
It sounds pretty good IMO although loud. I had to re-install twin 3" resonators but if you run a Cat it will be mellower.
There's not much room to bend pipes for a single muffler as there is on pre 00 Bonne's.
Last edited by 2000Silverbullet on Sat Jul 30, 2011 1:23 pm, edited 1 time in total.
JG2000SE
Post by JG2000SE »
Awesome, thank you 2000Silverbullet for the pics =D> , that is exactly what I had in mind for my own set-up, and thanks everybody for the responses. I found out some of the new Flowmaster ForceII axle-back systems for V6 cars come with 60 Series Delta Flow mufflers and they sound great. I know my car will not sound exactly the same but, that is what I will go with, a good moderate and smooth tone.
exp069
Year and Trim: 1996 pontiac bonneville ssei
Post by exp069 »
i have a 96 with no cat and dual magniflows and it sounds great.
willwren
Post by willwren »
exp069 wrote:i have a 96 with no cat and dual magniflows and it sounds great.
And that lack of a cat is probably costing you some low-end torque. Running catless won't benefit you until you hit the 400chp mark. Aside from that, running catless can get you into trouble, especially if someone turns you in for the EPA reward, whether it's a member here, or a shop that puts your car on a lift. Cats are required in all 50 states regardless of local emissions testing.
Both of my cars lost bottom end during short runs without cats due to clogging, but both were replaced. Get a high-flow magnaflow or carsound cat and I'll bet you'll feel the improvement off the line.
