please help me
mrsnrobinson
Year and Trim: 96 bonneville se 3.8 l 6 cyln
please help me
Post by mrsnrobinson »
I have a 96 bonneville se 3800 series. Not supercharged. After driving for about 30 to 45 mins the rpms jump erracticly and the battery gauge jumps as well as the oil gauge. The car feels like its going to take off on its own then starts hesitating and surging. So far i have replaced the coil packs, ignition control module., fuel pressure regulator, thermostat, altenator, battery, spark pkugs, wires, and the crank position sensor. The throttle body was cleaned and the lower intake manifold was replaced as well as the gasketa. Running out of money!!!! Help please!!!! 78,000 miles
wake
Year and Trim: 96 olds cutlass supreme 4 door
Re: please help me
Post by wake »
..did you say it wasnt throwing any codes or a service engine light/check engine light ??
kinda sounds like the symptoms of a cam shaft position sensor on its way out :???: not for sure though
also, call me crazy but how are your battery terminals?
:headbang:LUCAS Image Member # 534.
96 olds cutlass supreme SL 4 door 3100 4t60 *3.33 gears* *Fe1* 115K bone stock DD
Bing
Year and Trim: S
Re: please help me
Post by Bing »
I was going to say battery cables. :bhuh:
mrsnrobinson
Re: please help me
At this there is no crazy answer. Lol battery cables are good. And yes no codes. Crazy I know but true.
mrsnrobinson
Re: please help me
good or bad but i got a check engine light. code came up as PO133 (oxygen sensor). another code came up as the engine coolent temp sensor. also was told the computer may be causing this and may need replaced. :btruestory:
anyone have any ideas? :bhuh:
Re: please help me
Post by Jrs3800 »
First, Check the grounds on the passenger side of the car, as well as the grounds on the drivers side of the car...
There is a thread for this somewhere...lol
mrsnrobinson
Re: please help me
Funny you should mention that. The other day the car wouldnt start at all and i had it towed the shop. They said the motor in drivers seat was bad and draining the battery. But does that explain the problems i have been having? Seems to easy lol
