Heres the link:
http://www.midwest3800.com/forum/kb.php ... icle&k=187
I basically bought the parts as listed from the sources on the link.
The only little hiccup I had, was when I pulled the 1-2 spring out. It left the stamped spring base on the piston, just took some finagling but it came out. Other than that it went as described. I installed the firm shift kit, which really isn't that harsh just a lot quicker.
Heres all the parts laid out before starting this afternoon.
Bottom view of the car
This is the accumulator with the 1" spacers installed.
Heres that spring base I was talking about.
I bought 2 new 2-3 springs, figured the one has been in there for 100,000 miles good time to replace it.
Then after that I bolted the accumulator back together and reinstalled it. I then installed the new filter and filled the tranny back up. Ended up needing to buy 1 more quart of fluid to get the level just right.
Took it for a drive and what a difference it made. It cut my MS shift time almost in half. It's not really that aggressive of a shift kit, makes it just right.
So with this and the new tranny cooler done, I should be able to keep the tranny happy for a little while longer.
