So heres the list, in order of whats next.
-Home made tranny shift kit: http://www.midwest3800.com/forum/kb.php ... icle&k=187
-High speed cooling fan over ride switch.
-Install A/C delete pulley and unhook old A/C system. I'll be leaving the condenser in place to continue protecting the radiator. The compressor took a dump and I don't care if I have air or not.
-Make up new battery cables.
-Home made fuel pump hot wire kit, and with a 4 awg. wire from the alternator to the power distribution center.
-Home made headlight relay kit, just to make them a little brighter.
-Go through front end (suspension and steering wise) and replace just about everything.
-Install series III injectors and fuel rail. I have the rail, injectors, and the connectors for the injectors for this swap. Plus I'll do hard line with a short flexible connection to the fuel rail, and get rid of the plastic lines that are there now. Then I just have to rework them a little by the tank.
-New tires all around.
-Buy and install a P-LOG.
-Buy and install a new down pipe 2.5" maybe 3" and high flow cat, with rear O2 delete.
Then I'll have to have the PCM reprogrammed at this point or just before.
-PCM mods would be: Rear O2 delete, Vats turned off, Fan turn on temp adjusted for 180* thermostat, Adjustments made for FWI, L26 injectors, Plog, Down pipe, and high flow cat.
Well, thats it for now but you get the idea.
Member # 534.
