blower speeds
xvr843
Year and Trim: 1996 se
blower speeds
Post by xvr843 »
blower will not change speeds, change the resistor and fuse still no change
Dads Toy
Year and Trim: 1996 Bonneville SE
Re: blower speeds
Post by Dads Toy »
Need a little more info. Do you have a electric temp control unit or is it manual? and what speed is it at when on?
Bonneville SE 3.8 V6, Modified Throttle Postion Sensor, Platimun Plugs, Kummo Touring tires.
xvr843
Re: blower speeds
Post by xvr843 »
manual, high it will go is second, i am from sc as well, Hampton County
Dads Toy
Re: blower speeds
Post by Dads Toy »
if you can get two speeds out of it and the blower does come on, I would think its the fan switch. One way to test it is to deconnect the connector at the fan motor and check the volts going to the motor. Should get an increase in volts with each click of the switch.
