Rear Sway
- AJT2004
- Posts like an LG3
- Year and Trim: 2004 Bonneville SE
Rear Sway
I am about to get a rear sway from harofreak00. my question is, does it bolt up to the se?
- AJT2004
- Posts like an LG3
Re: Rear Sway
Also if its not too much trouble, could someone post a few pics of the rear sway bar on the car so i can see where it mounts. I just
removing my rear tire to get an idea but i would like to be sure. Thanks
- Phantom
- Year and Trim: 1998 Bonneville SSE
Re: Rear Sway
That depends what car is it from?
Re: Rear Sway
You will want the bar, the frame brackets and the bolts for them, then you'll need to get bushings and end-links. I believe all the mounting points and holes are there.
- willwren
- Retired Admin
Re: Rear Sway
Do NOT use the endlinks from the donor car. Buy new.
Re: Rear Sway
Oops, forgot to put new in-between "get" and "bushings". Get new bushings and endlinks.
