I opened the trunk yesterday to find the carpet and some stuff wet. Well, lo and behold, the spare tire well was overflowing with water. I found lots of posts here about various common leaks on this vehicle. After sitting in the trunk for 20 minutes on this 88 degree day I found a leak under the gasket near the trunk latch. The latch itself was very loose and I have tightened it. I pulled the gasket off and it looks like someone gobbed a bunch of sealer on the lip and it is failing. It looks like there is some sort of factory sealant all the way around the gasket. It's sort of a translucent yellow color, soft and tacky. The stuff that was gobbed on is not at all tacky. Sort of looks and feels like silicone sealant.The only gasket sealant I can find locally is from 3M but it seems to be a permanent bond. Apply to both sides, let it dry, then push both pieces together. Should I be using this stuff? Should I need anything at all?
I forgot to mention it's an '05 if that matters.
Found trunk leak - need advice
bhaze
- LE Member
- Year and Trim: 2005 GXP
vogie01
- Posts like an L27
- Year and Trim: 2002 SLE
Re: Found trunk leak - need advice
Working on a similar issue at the moment on my 02 SLE. Try to turn the seal first, and see if it stops leaking. Mine did not, so I am going to replace the seal. Not sure what was used, but I am sure someone knows what it is. I am going to the glass shop and get whatever they recommend.
bhaze
- LE Member
If you can post back with what the glass shop recommends it would be much appreciated. I'm taking a long trip this weekend so I had to throw it back together and hope for the best. I did press on some rope caulk (the kind I use around my leaky house windows in the winter) hoping it will help at least a little. It's the best I could come up with without making a mess of the whole thing while waiting for the long term solution.vogie01 wrote:Working on a similar issue at the moment on my 02 SLE. Try to turn the seal first, and see if it stops leaking. Mine did not, so I am going to replace the seal. Not sure what was used, but I am sure someone knows what it is. I am going to the glass shop and get whatever they recommend.
vogie01
- Posts like an L27
Yeah, no problem. I am going to go in see what they use on outdoor applications in such a situation.
- GXPete
I had the same issue when I bought my Bonnie and I actually rectified it with hot glue, but the OEM stuff they used may be a better bet, if applied correctly. Also check for leaks at the rear sunroof drain tube connection points in the trunk, if applicable, and the rear shock towers. Given your observations though, sounds like the same issue I had.
2005 Bonneville GXP (SOLD), Crimson Red Tintcoat
Other Rides: 2009 Solstice GXP Coupe #606, Cool (Liquid Silver) | 2007 BMW 750Li, Toledo Blue Metallic
Past Rides: 2007 Grand Prix GXP, Red Jewel Tintcoat | 2004 Grand Prix GT2, Fusion Orange | 2002 Bonneville SSEi, Black | 1999 Regal GS, Black | 1997 Bonneville SSE, Blue-Green
1994 Cutlass Supreme S, Turquoise | 1989 Cutlass Supreme IS, Bright Red | 1988 GMC Sierra 1500, Dark Red | 1982 Regal Sport Coupe, Maroon/Silver | 1975 LeSabre, Beige
Wife's Chariot: 2006 Buick Rainier CXL, Red Jewel Tintcoat
