air bag
dmb201
Year and Trim: 1995 Bonneville se
air bag
Post by dmb201 »
where is the airbag module in a 95 Bonneville se with bench seets and how do i disable the air bag system. i have a steady airbag light when the car is running. :banghead: :helpsmilie:
Owner of one of the best cars ever
95 Bonneville se amen!!!!!
RJolly87
1994 Buick Regal Custom
Re: air bag
Post by RJolly87 »
The module is located under the front passenger seat.
~Randall~
1fatcat
Year and Trim: before cars
Re: air bag
Post by 1fatcat »
There are a few ways to disable it, but the easiest and safest way is to just disconnect your battery and wait 10 minutes before working on it.
Edit: the 10 minute wait gives the module time to bleed it's power off. Like letting a capacitor drain.
dmb201
Re: air bag
Post by dmb201 »
ok so if the module is bad where can i get a new one. or one that is rteferb. how much.
Re: air bag
Those are generally a dealer-only item. You might get lucky and find one in a junkyard.
dmb201
Re: air bag
Post by dmb201 »
If I call gm could they sell me one. But my biggest concern is the price.
Re: air bag
It's either them or the junkyard.
dmb201
Re: air bag
Post by dmb201 »
Looks like I'm gone juncking :banana: :banana: :bwoohoo:
Thanks alot
Re: air bag
You may have to have the dealer program it, however. I'd call them and ask before you plug it in to find either the light is on, or the air-bag just exploded in your face, lol.
dmb201
Re: air bag
Post by dmb201 »
The junkyard I go to is like the best in the USA
stoystown auto wreckers
Theynshould be able to do it for me.
Re: air bag
I don't think they'll have the equipment (Tech II) to program the module to your car. They'll find it, but you'll have to put it in and take it to the dealer. Again, I'm not sure, call your dealer and verify.
dmb201
Re: air bag
Post by dmb201 »
Ok thanks alot for your help with this. :hail:
1fatcat
Re: air bag
Post by 1fatcat »
I don't think you will need to program it beings it's a 95. I think the programable ones didn't start till 96?
willwren
Re: air bag
Post by willwren »
I know for a fact that 92-95 don't need programming. But the one you get from the wrecker has 50% odds of being bad also. The mounting location is prone to corrosion due to water in the cabin. It's at the lowest spot inside the car.
dmb201
Re: air bag
Post by dmb201 »
well i found one for 45$ is that a good prise for used or what
1fatcat
Re: air bag
Post by 1fatcat »
Sounds fair as long as they warranty it.
dmb201
Re: air bag
Post by dmb201 »
:bwoohoo:
dmb201
Re: air bag
Post by dmb201 »
i looked at the light today and it was steady with key on steady wile cranking and steady wile idling. does this help with diagnosing the problem
