The cluster says it has 160k miles on it, but I'm curious if that is correct, as the oil change sticker on the windshield reads 99,000 with a date of 09. I have no idea how long the car has been stolen, or if the cluster has been swapped. I'm going to run a carfax on it and see what the last recorded mileage is.
Known things wrong with it:
Driver window busted out
Driver front window regulator broken
Driver rear window regulator broken
Front bumper missing
Headlight wiring is cut
Ignition switch is broken & missing
Dash is broken up
Missing center caps
Heated seat switches are broken
Hood is scratched up
Catalytic converter is cut out
I did some work to it this weekend. I fixed both of the drivers windows, new regulators and glass, so everything is waterproof again. I put the front bumper back on. I put some center caps on it. I put in a used ignition switch and PassKey module, did the 30-minute relearn, and the car fired right up! It runs great, other than being super loud from not having a cat.
I'll post some new pictures tomorrow, ran out of light today.
Member # 534.
