'01 SSEi aftermarket install
mlkmgr
Year and Trim: 01 Bonny SE
Post by mlkmgr »
I apologize if this has been asked/posted before but my internet has been waaay slow these last couple days. took 2 minutes to load this page and trying to search just isnt happening.
as the title states I am attampting to install an aftermarket HU in my cousin's 2001 SSEi. I am using the scosche GM07B wiring harness but cannot get the unit to power on. Am I better off just hard wiring the constant, switched, ground, etc? or will this harness suffice? secondly, is there any other info needed for this install? i am pretty sure there is an aftermarket amp somewhere in here but just uncertain where and if I need to wire the remote turn on to the factory amp somehow.
Thanks to anyone that can offer any advice.
cammo87
Year and Trim: '00 ssei
Re: '01 SSEi aftermarket install
Post by cammo87 »
does the vehicle have the factory bose system?
Bugsi
05 Mercedes S500 4Matic
Post by Bugsi »
Title of the post says SSEi, so I'd say yes. (Bose was standard equipment on SSEi, right?)
`05 Mercedes S500
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
IIRC the switched power was not exactly where one wouldve expected. I only use the factory power wires so i just hardwired them, its been so long I cant recall exactly where I had to pull power from.
jonnevilleSSEi
Year and Trim: '97 SSEi
Post by jonnevilleSSEi »
Scosche has pretty good tech support. Not perfect mind you but sometimes the mfg. of the parts is the best bet. Please come back and share if you learn the secrets from them.
'97 SSEi, Majestic Teal / Beige interior, Bose, HUD, iPod ready! - SOLD! :sad: Check it out!
'99 Buick Regal LSE, Matador Red / Beige interior - SOLD! Check it out!
'96 Chevy Camaro - White w/Black / fire red interior, 3800, manual, loaded, T-tops, Bose - SOLD! Check it out!
Jeff2002WS6
Post by Jeff2002WS6 »
There was something on my harness that was like pen 3 and 6. Used 3 for 00-01 and 6 for 02+. Might be worth looking into.
