Ign adv
ijreed
Year and Trim: 1996 Pontiac Bonneville SSEI
Ign adv
Post by ijreed »
i have a scanner and it has something on it called ign adv i was just wondering what this is.
willwren
Re: Ign adv
Post by willwren »
The PCM advances the ignition timing as much as it can based on the conditions (fuel octane, temperature, knock, etc) to improve power and efficiency. If it detects knock, it will retard the timing.
ijreed
Re: Ign adv
Post by ijreed »
so what are the numbers typically supposed to range from, and what are they supposed to be at WOT. At WOT its goes to 14 is that bad and in normal driving operations its about from 27 to 34
Re: Ign adv
It is going to vary based on a lot of factors. Some of which Bill mentioned along with things like load on the car, flat or steep hill quality of the gas etc.
ijreed
Re: Ign adv
Post by ijreed »
so is there number where KR occur if so what numbers
bonnevillain
Re: Ign adv
Post by bonnevillain »
That will also depend on the car, the temperature, and the gas being used. KR is a separate parameter which some scanners can read.
ijreed
Re: Ign adv
Post by ijreed »
so where can i find one of thos scanners and thanks for the info
LeSabre in Buffalo
Year and Trim: 2012 Eco
Re: Ign adv
Post by LeSabre in Buffalo »
My L36 advances timing to 44* on occasion. It's kinda funny to watch.
willwren
Re: Ign adv
Post by willwren »
ijreed wrote:so where can i find one of thos scanners and thanks for the info
Auto Parts stores, online, Sears, etc.
