2001 bonneville horn
nicholshornlake
Year and Trim: 2001 bonneville se
Post by nicholshornlake »
I've been on about every Pontiac forum I can find and still don't have the answer. I have a 2001 Bonneville with horn problems. Fuse and relay are good. Problem is I can't find the horn. I know it's somewhere on the driver's side around the headlight. I removed the headlight and searched til I was blue in the face. Can anyone give me directions as the easiest way to get to the horn? Thanks :banghead:
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: 2001 bonneville horn
Post by 01bonneSC »
Have some lay on the horn while you look under the hood lol
Under/around the air box i believe. Not positive as I have not looked for mine.
Jeff2002WS6
Post by Jeff2002WS6 »
Mine is down low on the frame when you remove the drivers side headlight. Follow the 2wire harness down to it.
Remove the driver side wheelwell extension by the bumper cover. Best way to access it.
nicholshornlake
Thanks harofreak00. Your advice lead me right to it! Thanks again.
