Look what followed me home!
99bonnieSE
Year and Trim: 1994 K1500 Silverado
Re: Look what followed me home!
Post by 99bonnieSE »
2000Silverbullet wrote:For a little cheap car it's not too bad.
I had to change out the stereo though. The rear speakers were blown.
What a huge difference with a flash drive modern deck and high power 6x9's. :banana:
I even got the cruise control to work. All it needed was a brake switch. Ya, you know I'll never use it but "others" might. My wife likes to cruise and rest her healing foot. :wink:
Not planning to do anything else to this little FaartFire.
It needed a good sound system because it has no noise isolation and you can hear every bit of road noise. :roll:
Sound Deadener!!
http://www.sonicelectronix.com/item_277 ... RKXTK.html
definitely quite the nice car! cousin just got it's twin.
It's been a very long time, but, I am still around!
2000Silverbullet
Post by 2000Silverbullet »
I plan to use some roofing tar in the spring. Much cheaper and probably lighter than a lead based deadener.
2600 lbs is 1200 lbs lighter than my Bonne. ;)
Still working on the first tank of fuel. Plenty left and wife is using it every day while I use the Jeep.
dpcookson
Year and Trim: 1982 Chevy S10
2003 Ford Focus
1996 VW Jetta
Post by dpcookson »
2000Silverbullet wrote:I plan to use some roofing tar in the spring. Much cheaper and probably lighter than a lead based deadener.
#-o
Dale
99bonnieSE
oops, lol
2000Silverbullet
LOL don't knock the quality of roofing tar. It works wonders. On the outside or inside. :booty2:
Just brush it on. It sticks like glue, dries quickly with no odour and stays flexible.
I learned that trick living in a harsh northern climate where auto bodies never lasted longer than 4 years before they completely rusted out from winter driving. ;)
99bonnieSE
2000Silverbullet wrote:LOL don't knock the quality of roofing tar. It works wonders. On the outside or inside. :booty2:
I gotta believe ya on this one.... i've heard about that before . I wanna run truck bed liner on the bottom of my cab on the blazer. Then use the POR-15 or chassis saver along the frame rails... i used the rustoleum Hammered-on paint and i was real suprised at how that stuff works. But, i want something even more solid when I have the money.
2000Silverbullet
The problem with other products like bedliner is you need a completely clean surface for good bonding. Only works well on a new car.
Roofing tar on the other hand will stick well with just a good cleaning to make sure all the loose stuff is off. ;)
....and it's a lot less expensive.
Last edited by 2000Silverbullet on Fri Jan 21, 2011 10:21 pm, edited 1 time in total.
