HVAC cleaning procedure
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Re: HVAC cleaning procedure
Seemed like it gained a little bit of flow. The main effect was how quickly the A/C came on. The time was significantly lessened until I had cool air. The car wasn't driven, so I didn't get to experience how cold it could have been. It was pretty durned cold for merely idling, where it wasn't quite as cold before IIRC. Could be a placebo, but it's a cheap enough placebo!
- JMH1950
- Posts like an L36
- Year and Trim: no longer a Bonneville owner
Appears to be something else not available in Canada.
Any recomendations for an alternative?
2001 F150 a basic six cyl with 5 speed manual trans.wjcollier07 wrote:Darn it John...now you got me thinking mine's not big enough.
'66 Piper Cherokee 360 CID , 180 hp, 155 mph @ 2500 rpm, drop in K&N filter.
- Boreas
- Posts like an L36
- Year and Trim: 1993 SE
1996 SSEi
1997 SSEi 40th - Location: Chi-Town
Thanks for the pictures. Pictures for dummies like me is always helpful. :D
1993 Bonneville SE "Old Ironsides" 244,xxx - Junked.
1996 Bonneville SSEi "Double Trouble" 164,xxx - Stock
1997 Bonneville SSEi 40th "Purple Spaceship" 204,xxx - Aeroforce Interceptor, B&M 70264 Trans Cooler, Intense FWI, High-Flow Feline, non-Bose head unit w/ 5 band, Alpine 6x9's, 3.5 MPS, SD Headers, rear disc brake conversion. Future: 1.9 Rockers
1997 Buick Park Avenue "Blue Floaty Thing" 124,000 - Daily Driver/Winter Beater
- willwren
- Retired Admin
Any carb cleaner that won't disolve the plastic housing or melt carpet.
- John Deere Boy
- Retired Moderator
- Year and Trim: 1993 SSE
Member since Nov 2003 - Location: Centerville, IN
If you can't see any grime you may not get a noticeable difference. 92-99 bonnies have weak airflow. Blower motor failures are rare but not unheard of....it is more common for the blower controller module or air mix door to fail.White93Z34 wrote:to add to this, a few days ago I read this and checked out my evap core, it looked nice and clean, didn't see any point in cleaning it, however I have moderately poor fan performance, how often to the blower motors themselves die?
White93Z34
- SSE Member
- Year and Trim: 1997 SSE
thanks, like I said when I pulled it all apart the evap core looked nice and clean. I guess the fan isn't all that powerful in the first place.
-Chris
1992 Chevrolet Lumina Z34 3.4L TDC v6, Hydramatic 4T60E
1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
1997 Pontiac Bonneville SSE 3.8L v6, Hydramatic 4T60E
1987 Chevrolet Camaro 5.0L v8, Hydramatic 700R4
nicklikesmilk
- Year and Trim: 98 Oldsmobile Intrigue
would brakekleen (sp?) be safe?willwren wrote:Any carb cleaner that won't disolve the plastic housing or melt carpet.
1993 Park Avenue
200k, well-optioned, and running strong
- willwren
- Retired Admin
I suppose you'll tell us if it dissolves the plastic housing around your evap core. I suggest you test it on a small area.
- SSEimatt93
- Senior Moderator
- Year and Trim: 2016 Scat pack
I used Wurth Brand Brake Clean on mine the other day at work, My core wasnt dirty at all, but i still used most of a can, and quite a bit of water, without flooding my interior...thankfully.
Seems good to go now, it did get rid of a musty AC smell..
2016 Dodge Charger Scat Pack 392
3.09's 8 Speed Auto
04 GTP
3.09's 8 Speed Auto
04 GTP
