(If you install a 3" or so pipe from the intake and have the filter in the engine bay)
Hotter air contains less oxygen, meaning less power, meaning less fuel used.
hotter air contains less oxygen which means your vehicle will suck in more air to make the same amount of power, making it less efficient. You should get worse mileage with hotter airHans wrote:Adding a HAI will give you 2MPG.
X Infinity. Cooler air is denser, allowing you to burn your fuel more efficiently.bonnevillain wrote:hotter air contains less oxygen which means your vehicle will suck in more air to make the same amount of power, making it less efficient. You should get worse mileage with hotter airHans wrote:Adding a HAI will give you 2MPG.
Except in the dead of winter when you'd expect to get better gas mileage, they change the gas formula so we get a little less mileage out of a gallon of gas.00Beast wrote:bonnevillain wrote:X Infinity. Cooler air is denser, allowing you to burn your fuel more efficiently.
yourgrandma wrote:High
EXACTLY!!!bonnevillain wrote:yes, but the main point is cold air isnt one of those factors
Yep. Actually it isn't even the fact that the air is cold, it is the Density of the air the engine is breathing.bonnevillain wrote:yes, but the main point is cold air isnt one of those factors
That isn't just sacriledge, doing that will send you straight to hell!clm2112 wrote:bonnevillain wrote:I know this may be sacrilage...but an option for the FWD crowd would be to walk away from the venerable 3800 motor and do an engine swap to a smaller displacement 2.8, 3.1, or 3.4 motor....of if a crashed Caddy CTS shows up in your local wrecking yard, go for the LY7 3600 CVVT motor
Then to hell I go... The LY7 is rated at 255hp @6200rpm... that's actually more power on tap than a lot of the stock N/A 3800 motors. If the right motor shows up at the right price, then my advice is to roll with it.00Beast wrote:That isn't just sacriledge, doing that will send you straight to hell!
