Water leak I can't seem get to
Trums2
Post by Trums2 »
I have finally found my water leak, but I don't seem to be able to find an replacement part or how to remove the part. The piece is located under the supercharger and seems to be coming out of the intake manifold. It's a small tube of plastic that turns at a right angle and heads to the back of the engine. Does anybody know what this part is called and hor to get it out to replace it. This poor car goes through about a gallon of water every time I go somewhere.
Re: Water leak I can't seem get to
It's the coolant elbow. You'll have to remove the belts, alternator, then the bracket it goes into. There are 2, the one you can see, and another on the bottom. They can be found in the Dorman HELP! section of any auto parts store. It's 45 minutes and $20.
Dorman Help! 47065
Trums2
Post by Trums2 »
Awesome thank you so much for the help.
blackbeauty00
Year and Trim: 2000 bonneville SSEi, all stock
Post by blackbeauty00 »
i have same problem... does the upper intake gaskets go out on supercharged cars? mines using a lot of coolant to and couldnt figure where it was coming from, i was told it was the intake gaskets, but it didnt sound right. and im not using dexron.
2000 Pontiac bonneville SSEi, stock motor, gutted air box with K&N, tan interior, grill painted silver, clear headlights and taillights with silverstars, tinted tails
future mods: FWI, touch up paint, eventually a smaller pulley, HIDs,
wifes car-2006 Grand prix white, all stock-she wont let me mod it
Lower Intake gaskets still fail. I would definitely replace them.
blackbeauty00
i narrowed it down to a bad lower Radiator hose. should i still to the lower intake gaskets?
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
blackbeauty00 wrote:i narrowed it down to a bad lower Radiator hose. should i still to the lower intake gaskets?
Yes with the aluminum ones if they haven't been replaced before.
