how to remove 1997 bonny sse engine?
stevedonadio
- Year and Trim: 1997 pontiac bonneville ssei
hi i am very good with cars, brakes ,tuneups, etc. but i need to remove an engine and install a new one...i would really like to do it with my son this way he learns and appreciates the bonne more.......can someone send me a video or step by step instructions.........also,the new engine that i am putting in is not supercharged ,can i put the supercharger from the blown engine onto the new one?
- J Wikoff
- Year and Trim: 1992 SSE
Re: how to remove 1997 bonny sse engine?
The motor you are putting in has higher compression and weaker internals. It will be ill suited to running well or long term.
If you do it, you'll have to swap the heads for the injector bosses, LIM, SC, throttle body, fuel rail with parts. Then you'd have to have a custom tune done, and probably install a larger SC pulley to lower the boost so it doesn't grenade because of the higher compression.
If you don't put the supercharger on, you'll have to do a different custom tune, as well as remove some trouble codes for the supercharger specific sensors. Or put in an NA PCM and probably some wiring harness changes.
IMO, get a supercharged engine and save yourself a whole lot of time and headache.
If you currently have a supercharged engine you had better get a supercharged engine. You'll have tons of issues if you don't....
stevedonadio
the car i am buying is a 97 ssei supercharged 40th anni.. the engine is blown.... the engine i am gonna put in it is not supercharged...is that ok?00Beast wrote:If you currently have a supercharged engine you had better get a supercharged engine. You'll have tons of issues if you don't....
stevedonadio
J Wikoff wrote:The motor you are putting in has higher compression and weaker internals. It will be ill suited to running well or long term.
94SilverSSEi
- Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi - Location: Racine, Wisconsin
No. You are going to want to get a supercharged engine.
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
No, it's not OK. Find the right engine either in a junkyard or for sale on craigslist, etc. Where are you located? You can either use the Series II Supercharged from a Grand Prix GTP, Park Avenue Ultra, Buick Riviera Supercharged, Bonneville SSEi and 04-05 Impala and Monte Carlo SS Supercharged or the Series III supercharged from an 04+ Grand Prix GTP or 05+ Grand Prix GT Supercharged.
stevedonadio
00Beast wrote:No, it's not OK. Find the right engine either in a junkyard or for sale on craigslist, etc. Where are you located? You can either use the Series II Supercharged from a Grand Prix GTP, Park Avenue Ultra, Buick Riviera Supercharged, Bonneville SSEi and 04-05 Impala and Monte Carlo SS Supercharged or the Series III supercharged from an 04+ Grand Prix GTP or 05+ Grand Prix GT Supercharged.
i already have a smashed bonne sse series 2 complete car just smashed up.. cant i take computer out of it with the engine and put it in the ssei ?
stevedonadio
94SilverSSEi wrote:No. You are going to want to get a supercharged engine.
No. You would have to swap the entire harness, and you'd be going backwards.
- J Wikoff
You can swap all the necessary parts, but it is a lot of hassle. Getting a supercharged engine will be much less of a pain.
If you really have to use the NA engine, we can get you there, but it'll take some time to get it all right.
Find a supercharged engine and find another car to use that L36 in. It's not worth the hassle to try to swap in the N/A motor into the supercharged car.
There is a lot more difference between the 2 engines than just throwing a supercharger on top.
Listen to these guys, do not put a NA into your SSEi.
1oldman
Is it just me or does stevedonadio have worse reading comprehension than I do? LMAO!!!!
Let's not be bashing other members oldman. He's trying to understand, cut the guy a break.
1oldman
sorry, but it is amusing to me that someone is worse than me. I now finally have company. lol!
