OnStar Antenna.. able to use as CB Antenna?
- CDawg011
- SSE Member
- Year and Trim: 2001 Pontiac Bonneville SLE
Is there anyway I can use the OnStar antenna as a CB antenna? I never use onstar anyway...
2001 Maroon/Red Bonneville SLE. (Pictures to Come Soon)
My uncle is trying to get me to name my car Suzabel.. Pass or Fail?
To all the Mustangs... I can haul @$$ AND a family.
There are only two things I like to see in a bra, and a car is NOT one of them.
Re: OnStar Antenna.. able to use as CB Antenna?
No. It's designed for cell signals, not CB. Plus it's probably not long enough. Who uses CB anymore...
01bonneSC
Truckers....00Beast wrote:No. It's designed for cell signals, not CB. Plus it's probably not long enough. Who uses CB anymore...
- CDawg011
- SSE Member
I don't care if it's long enough or not.. just wondering if the end of it would screw into a cb...00Beast wrote:No. It's designed for cell signals, not CB. Plus it's probably not long enough. Who uses CB anymore...
With the right adapter I'm sure you could, I think its just a standard BNC antenna connection.
bonnevillain
- Year and Trim: 2002 SLE
The wavelength for CB band is almost 40 feet long. Antennas usually come in 1/2, 1/4, and 1/8 wavelengths. The 1/4 is the common big one you see on trucks. An antenna as small as the OnStar one won't work very well, even if you connected it.
- CDawg011
- SSE Member
like i said... it doesn't matter how big the antenna is or if it will work well.. i just need to know if it will screw into a cb.. period.bonnevillain wrote:The wavelength for CB band is almost 40 feet long. Antennas usually come in 1/2, 1/4, and 1/8 wavelengths. The 1/4 is the common big one you see on trucks. An antenna as small as the OnStar one won't work very well, even if you connected it.
bonnevillain
No, you'd need some kind of adapter.
- CDawg011
- SSE Member
okay thanksharofreak00 wrote:With the right adapter I'm sure you could, I think its just a standard BNC antenna connection.
Bonneville92V688
- Year and Trim: ‘12 Jeep Grand Cherokee Overland Summit
You would be surprised.. a LOT of people do, including my Dad and my neighbor.00Beast wrote:Who uses CB anymore...
1996 Thunderbird LX - 3.8
95SLE
- Posts like a Northstar
- Year and Trim: 2004SLE
After being involved with a Tacoma forum I found that all of the off road guys and gals have a CB set up in the truck.00Beast wrote:No. It's designed for cell signals, not CB. Plus it's probably not long enough. Who uses CB anymore...
I also found that it cost a lot more to go slow and over rocks than it does to go fast in a 1/4 mile.
2004 SLE Crimson Tintcoat with Dark Pewter Interior. Mods so far: Wood Dash Kit-Window Tint-CATZ Fog/Driving Lights
Custom Fabricated Stainless Steel Mesh Grill-Painted Calipers-3rd Brake Light Decal-Strut Tower Brace.INTENSE™ Level 1 L36/L26 Performance Package, Intense Shift Kit. ZZP ER Rockers and a HV3. L76 springs
COTM April 2007
smokeysan
- LE Member
- Year and Trim: 2001 Pontiac Bonneville SE
2005 Chevy Suburban Z71
I used to run one when I was traveling every weekend from Fort Benning, GA to Tampa, FL. I used it to try and get a heads up on speed traps etc.00Beast wrote:No. It's designed for cell signals, not CB. Plus it's probably not long enough. Who uses CB anymore...
RJGill84
You should be able to find a very cheap adapter that goes from BNC to whatever the CB connection is, probably $10 or so. Also, you can replace the OnStar whip with a CB whip available at RadioShack very easily. They make through-the-glass CB antennas that use the same screw-in portion as the OnStar whip - it's as simple as unscrewing/screwing lol.
"SLE without the ugly" - leather, climate control, sound, 3.05 gearing, 180* t-stat, tints. http://www.gillsystems.com
- CDawg011
- SSE Member
Sweetness. ThankRJGill84 wrote:You should be able to find a very cheap adapter that goes from BNC to whatever the CB connection is, probably $10 or so. Also, you can replace the OnStar whip with a CB whip available at RadioShack very easily. They make through-the-glass CB antennas that use the same screw-in portion as the OnStar whip - it's as simple as unscrewing/screwing lol.
- Water 97SSEi
- Posts like an LG3
- Year and Trim: 1997 SSEi
My brother is 18 and has a CB radio in both of his two cars, a 92 Camaro and an 2000 Intrepid.Bonneville92V688 wrote:You would be surprised.. a LOT of people do, including my Dad and my neighbor.00Beast wrote:Who uses CB anymore...
1997 SSEi | Bright White | 170,000+ Miles | Stock | Best 1/4: 15.374
