Accidentally punctured front axle boot
Ken_W
- Posts like an L27
- Year and Trim: 2000 SSEi
Was trying to remove old stabilizer bar link and accidentally nicked the boot with something sharp. Now I have a 4mm hole that is slowly oozing grease. Not a good day -- this axle was perfectly fine otherwise.
I presume that the whole axle needs to be replaced now? How long can I drive the car before big problems will occur? Minutes? Hours? A few days?
Ken_W
Ken_W
Re: Accidentally punctured front axle boot
I think you can have a new boot installed, or install it yourself.
- bonnelover
- GXP Member
- Year and Trim: 2005 SLE
when i had my eldorado, yearssss ago, i bought a universal boot and installed it, worked great, no leaks. you take off the old one and the new one bands on both ends and you screw the boot together in the middle. it also came with grease, to put in the new boot.
05 SLE-Other rides: 2010 Buick Lacrosse, 1987 Dodge Dakota, fully restored
November 2010 COTM
- bonnelover
- GXP Member
if its your bonneville, here is the link to advance auto parts for the 2000 bonneville, it shows the replacement boot, less than $20 and you are on your way
http://shop.advanceautoparts.com/webapp ... =axle+boot
November 2010 COTM
- repinS
- Moderator
- Year and Trim: 09 G8 GT
As long as you tackle it soon enough (don't drive much, if you can avoid it) and get a new boot kit on, you should be fine. Make sure the grease remains plentiful.
- comatoast
Doing an entire drivers axle on mine next week, and after reading a bunch of online reviews and asking around NAPA seems to have the best quality OEM replacements, at least from what was mentioned to me and according to reviews. 00beast is probably getting sick of answering my laundry list of questions but ill ask one more
When im driving my steering is very stiff in the center position, meaning I actually have to use a little force to turn it, how most cars turn very easy at all speeds , this seems like it doesnt want to turn easily.. When parked it turns fine, but while driving it doesnt..
Fluid is full, dont see any leaks, so would this be the pump somehow or the bad driver axle that has covered my drivers fender with grease spitting from out the boot?
Current mods - FWI, Intense 1.0 PCM, 3.4"- 3.5", Intense MPS, AL 104s, 180 Stat , Intense/TG shiftkit, Aeroforce Interceptor scan gauge
Upcoming mods- 1.9 rockers, 105#springs, Headers, 103s, 3.3, tune..
- The_Maniac
- SSEi Member
- Year and Trim: 2004 Chevy Monte Carlo SS (L36 3800)
I had the same issue on my Grand Am (messed up the CV boot during another repair). I did not like the universal boots I saw (wrap around and screw together). I bought a OEM style boot and my father and I changed it ourselves (I don't recall the exact process). I believe it came with fresh grease to put in (grease is VERY important).
I later had to replace the opposite side half shaft on the car (I think a new half shaft was $60 plush a seal for the transmission). But if need just a boot, I'd get just the boot....
For more info about me and my cars, check out my websites below:
- 1984 Camaro Z28 5.0 Liter HO Restore Project/Big Toy
- 2004 Monte Carlo SS 3800 N/A Future daily driver
- 1994 Grand Am SE 3100 v6 Current daily with over 200,000 miles
Those Dorman boots look like OEM to me. Cut the old one off, install the new.
Ken_W
- Posts like an L27
Thanks guys for the info. After checking it out and finding out that AutoZone had a new axle only costing $40 more than the repair boot, I elected to just replace the whole axle.
I'm sure that the info posted here will be useful to future readers, since it appears that this event (puncturing boot) is not uncommon.
Ken_W
Ken_W
Haven't heard many good things about those cheap Autozone axles. I would have replaced the boot if I was you.
- The_Maniac
- SSEi Member
FYI - When replacing the axle, don't forget the transmission seal (otherwise, you might start loosing transmission fluid).
xrob
- GXP Member
- Year and Trim: 2002 Bonneville SE STOLEN
2001-05 Bonneville GXPI - Location: Chicago, IL
I'm experiencing a simiar issue. As i went in for a wheel alignment...i was told i need 2 front axle and new struts. I know my axle on the drivers side was leaking grease...I just need help also. My mechanic recommended we taking off the boot and taking the axle to a shop and getting a new boot inserted...and i ready to purchase new monroe quick struts...anything else i should be concerned about or getn replaced. I did my outer tie rods already?
