Wes noticed my pulley setup, so I guess I'd better share. So I appologize for the poor quality pics and if this is lite on details, since I did this almost 5 years ago, so pics are with a lame camera, and I don't have any of my notes or receipts handy, but I could find the paperwork and tear it down and re-photograph the setup if there's any interest.
Also, please be aware, that I did this NOT for any performance benefits, if there is a minor performance benefit (and I think there is) I do not have any objective measurements to back it up. It may sound stupid, but the main reason I did this conversion is that I wanted to be able to put the thrashercharged decal on my window, and wear the thrashercharged tshirt.
Anyway, here's what I did:
remove belt, remove pulley retaining nut, remove pulley -
buy the modular pulley system from thrasher for the magnuson nose drive, the magnuson nose drive is a non-tappered keyed input shaft, same dimensions as the M62 input shaft, have a local machine shop make an aluminum spacer for correct pulley offset, the thrasher pulley is the smallest they offer for the MPS system 2.74 inches -
hub with spacer placed on it -
stock pulley and custom thrasher MPS side-by-side, offset looks good -
hub installed, retaining nut installed, spacer in place -
pulley bolted to hub -
belt installed -
