step by step for thermostat replacment
1999_pontiac_ssei
- Year and Trim: 1999 150.000 kolomiters ssei
im woundering if anyone has like a step by step in pic form or instrutions on how to change the thermostat..at the same time what all would be needed to change it ...thermostat .. gasket..tools needed ect
pontiac help burning rice seince 1972
fwi waiting for money
1.9 rockers waiting for money
105 valve springs waiting for money
3.4 sc pully waiting for money
pcm flash waiting for money
104 spark plugs waiting for money
push rods waiting for money
shift kit waiting for money
areo force gauge waiting on money
hopeing for a lil more power but im waiting for money
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Re: step by step for thermostat replacment
Changing the thermostat is a pretty easy task. I don't have pictures for you though.
You'll need:
-Thermostat
-Thermostat seal (A rubber o-ring that goes around the t-stat. You shouldn't need an actual gasket, though there are gaskets you can get.)
-10mm socket, also an extension will probably help
-You will likely need a bit of coolant or water to top off the system when you are done.
-First you can either drain a little bit of the coolant, or you can loosen the bolts and let whatever comes out comes out, it won't be much.
-There are two 10mm bolts on the sides of the thermostat housing, remove those and move the housing out of the way. (To avoid losing any more coolant it'd be helpful to note to keep the housing end higher than the top of the radiator.)
-The thermostat will be directly under the housing and you can simply pull it out and replace it with the new one.
-There's no specific orientation for the thermostat besides top/bottom. Just make sure you put the new one in the same way, which would be with the spring side down.
-Put the thermostat housing back on and replace the bolts and tighten.
-Now you'll want to top off the coolant and run the car.
-To help air out the system open open the bleeder valve on top of the housing (It will either need a flathead screw driver or a 7mm IIRC) and with the car running and up to temperature, open the bleeder valve and let the air bubbles out. Wait until there is a steady flow of coolant coming out then shut it and you should be good to go.
You'll need:
-Thermostat
Last edited by WhiteArrow3800 on Tue Aug 24, 2010 12:46 pm, edited 1 time in total.
- willwren
- Retired Admin
99, you really need to read the forum section descriptions before you post. This is the second topic of yours moved today, and there have been others previously.
Moving to the proper section.
alexcoqui
- Posts like an L36
- Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
Here's one that I did a while back, hope it helps. viewtopic.php?f=12&t=6478
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
