keyless entry
keyless entry
i found a keyless entry on a 95 bonneville i would like to hook it up to my 94 bonneville. how do i find out if my car can use that keyless entry or can i have it reprogram it to mine, or is there any other way to get keyless on a non keyless car
Re: keyless entry
So you have a 94 Non Keyless car? Does your car have retained accessory and illuminated entry?( Pull up a locked door handle and the interior lights come on )
Re: keyless entry
Yes I have a 94. and the car does have both of those, i hope thats a good thing cause keyless would kickass
Re: keyless entry
That would mean that half of the system is there...
You will have to find the Trunk release to Trunk relay wire, Lock Wire, Unlock wire, And you will also have to add a relay for the Drivers door unlock Relay, and the drivers door unlock function will be separated from the Door lock relay and then be controlled via the Modules Drivers door unlock relay... I installed the system in my 95 Bonneville( PITA ) And I even added the Program wire into the DLC just like factory
There is a lot of homework to do with these systems...
Re: keyless entry
ok the worst thing about my car is that there isnt a trunk release button, i wish i could have that too i was thinking about ripping one out of a junk yard car but looks like a lot of work.
whats the whole process of doing this kinda hard to understand.
Re: keyless entry
Generally if you have Illuminated entry and Retained accessory you should have the trunk popper... Do you have a Blank spot on the drivers door under the armrest ?
Re: keyless entry
yea under the drivers armrest theres a blank plug.
Re: keyless entry
Next time you are in your trunk, look and see if there is a connector there that goes to nothing..
I think its sort of rare that we see these without Trunk Release
Re: keyless entry
in the trunk where key hole is there is wire that go to the black trunk latch but there connected what color wire would they be, and ive had my drive side door apart and theres no wire in there either so i im thinking i have the plainest SE bonneville around. lol
