fwi
1999_pontiac_ssei
- Year and Trim: 1999 150.000 kolomiters ssei
fwi
couple qustions what is the black box between the air box and the charcole canister...second this what dose the charcole canister do third forth where dose the black box go when you move it ?
pontiac help burning rice seince 1972
fwi waiting for money
1.9 rockers waiting for money
105 valve springs waiting for money
3.4 sc pully waiting for money
pcm flash waiting for money
104 spark plugs waiting for money
push rods waiting for money
shift kit waiting for money
areo force gauge waiting on money
hopeing for a lil more power but im waiting for money
1999_pontiac_ssei
Re: fwi
looking into it and i think it is the computer...what im woundering is dose it have to stay there or can it be moved about 6 inchs to twords the engine te give it clearenc... i will add a pic tommro of what i mean...at the same time could i see some pics of the fwi somepeopl on here have tso i could see the setup?
- willwren
- Retired Admin
Re: fwi
Relocate the PCM to wherever you like, and tie it down. It's waterproof. Relocate the charcoal canister to wherever it makes sense, and keep it active.
1999_pontiac_ssei
Re: fwi
what dose the charcole canister even do and how dose it work?
- willwren
- Retired Admin
Re: fwi
It extracts fuel vapors from the upper half of the engine and purges it back to the tank. It doesn't hurt performance in any way.
Barry
- Posts like an L27
- Year and Trim: 1999 SSE
Re: fwi
Here's some pics of mine. The pcm is up front and canister is out of the hole, allowing the filter to go in there.
1999 SSE. 112k, Cleared Corners, Mobile 1, Energy Suspension endlinks. Ported and Polished LIM, NGK TR-55 Sparkplugs, 180 drilled Intense stat, Flow matched injectors, Intense FWI, Intense PCM, MagnaFlow Cat.
- willwren
- Retired Admin
Re: fwi
Thanks, Barry. My pics don't have a PCM in that location, so my canister is farther forward. Perfect example for him right there.
Barry
- Posts like an L27
Re: fwi
Really pretty simple. I've heard some say they had to take fender filler off....I didn't. I was able to work filter into hole. Couple of plastic ties and it was ready to go. It is an Intense FWI. Most on the forum believe it is the best way to go if you are going to do a FWI. Here's pic of finished project.
- willwren
- Retired Admin
Re: fwi
No. I've already explained that in your other topic.
You don't have a PCM in that location, you will have to relocate your Charcoal Canister, and your throttle body is too small for a typical INTENSE kit. Please continue ask your questions in YOUR topic. Your application is different than the one being discussed here.
In addition, please make an effort to fully type your responses. This Forum isn't a texting paradise. Punctuation would be a big help too.
1999_pontiac_ssei
Re: fwi
next pay im thinging of makeing a fwi aswell as picking up a autoforce meter or what ever there called....would that be good for now....i will have about 35$ to play with and cant do any internale work where i only get 1 day off a week and need my car for going back and forth to work
- willwren
- Retired Admin
Re: fwi
You need to do more research before you 'make' a FWI. Theres' more to it than you might think, and if you do it wrong, it'll hurt performance, not gain any.
