Just ordered my new sub set up
99bonnieSE
Year and Trim: 1994 K1500 Silverado
Re: Just ordered my new sub set up
Post by 99bonnieSE »
Pretty clean wiring for the amp. I like it . =D>
It's been a very long time, but, I am still around!
lewis26
Year and Trim: 2003 SLE || 51k miles
Post by lewis26 »
The fastplug is awesome. Makes removing my sub sooo easy.
-Mike
kmalinich
Year and Trim: 1997 SE
Post by kmalinich »
lewis26 wrote:I am using the .7 box, as the t/s numbers for the sub show a .85 cuft as the optimum box. ...
What? Where did you get that number?
Seriously, folks around here...wow...
lewis26
Post by lewis26 »
kmalinich wrote: What? Where did you get that number?
By your lack of a counter-argument, It's safe to assume you don't know what you're talking about with audio and speaker driver design.
It's called a thiele/small parameter.
http://en.wikipedia.org/wiki/Thiele/Small
It takes various specifications of a loudspeaker to determine low frequency performance, and with the right equation can be used to get the optimum box value. Speaker companies use this to create minimum and maximum box volumes, with the optimum value usually being 75-80% of the maximum dictated by the manufacturer.
Now we can continue to argue this, and you can continue to demonstrate your incompetence, or we can truly accept the "/end box discussion" i had posted before and let it go. Your information is just wrong, and your attitude is childish and not welcome in my thread.
Additionally, if you don't like the "folks around here" then kindly leave, and nobody will miss you. You are not forced to be on this site, and your trolling in my thread is both unnecessary, and rude.
-Mike
99bonnieSE
:laughing3:
