2005 Bonneville SLE Spark plug
super_sk8er
Year and Trim: 2005 Bonneville SLE
Post by super_sk8er »
Please let me know how can I remove the spark plug boot and cables. It is so hard to remove.
J Wikoff
Year and Trim: 1992 SSE
Re: 2005 Bonneville SLE Spark plug
Post by J Wikoff »
If you are having trouble getting the wire boot off the plug, there are cheap plug wire removal tools. I've never used them, so I can't say how effective they are.
Archon
Post by Archon »
They can be very hard to remove, in particular the back ones, especially if they have been on the car for a while. Whatever goop was used originally glues itself to the plug. It comes down to twist and pull, several times. Some remove the rear engine lift bracket to get more room. If you have to, you could use some vise grips on the boot, being careful not to crush the metal sleeve. Either way, plan on replacing the wires. Liberal use of dielectric grease on the boots when you replace them will make the next time a lot easier.
super_sk8er
Archon wrote:They can be very hard to remove, in particular the back ones, especially if they have been on the car for a while. Whatever goop was used originally glues itself to the plug. It comes down to twist and pull, several times. Some remove the rear engine lift bracket to get more room. If you have to, you could use some vise grips on the boot, being careful not to crush the metal sleeve. Either way, plan on replacing the wires. Liberal use of dielectric grease on the boots when you replace them will make the next time a lot easier.
I did that but I could not pull the boot off. I am very afraid to break plug and cable.
"It comes down to twist and pull" meaning is push boot and twist certain angle?
grandprix104
Year and Trim: 2001 SE L36
Post by grandprix104 »
I had a very difficult time removing mine. I finally went down to Harbor Freight and bought some 11" needle nose pliers with a right angle bend at the tip. these worked very well to remove mine. I tried two of the boot pullers sold at the auto parts stores, but those tools bent and the plugs didnt budge.
Good Luck, and x2 on the dielectric grease on the new plugs.
Archon
Post by Archon »
Push the metal shields in as far as you can, then twist the boot while also pulling. The spark plug cables should be replaced, and if you break the plug, just replace that too....which I assume you're doing anyway?
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
Yeah you just gotta muscle up. Try getting boot removal pliers. and get a new set of wires cause u may destroy some.
Heres what the tool looks like.
http://www.arizonatools.com/img/product ... 990_TN.JPG
super_sk8er
01bonneSC wrote:Yeah you just gotta muscle up. Try getting boot removal pliers. and get a new set of wires cause u may destroy some.
Thanks guys, I will try them this weekend.
super_sk8er
Finally I removed them, but one wire was busted. I will insatll new wire and use dielectric grease on the boots. Thanks.
Sirius
Year and Trim: 2003 SSEi
Post by Sirius »
01bonneSC wrote:...Try getting boot removal pliers. and get a new set of wires cause u may destroy some. Heres what the tool looks like.
Alternate boot removal tool:
Resident Tightwad
Screw you, Photobucket.
95SLE
Year and Trim: 2004SLE
Post by 95SLE »
M80 FTW
Brings back a lot of fond memories.
2004 SLE Crimson Tintcoat with Dark Pewter Interior. Mods so far: Wood Dash Kit-Window Tint-CATZ Fog/Driving Lights
Custom Fabricated Stainless Steel Mesh Grill-Painted Calipers-3rd Brake Light Decal-Strut Tower Brace.INTENSE™ Level 1 L36/L26 Performance Package, Intense Shift Kit. ZZP ER Rockers and a HV3. L76 springs
COTM April 2007
