Sway Bar Bushings
Silver03Se
- Year and Trim: 2003 Se Bonneville
Sway Bar Bushings
Im installing a rear sway bar, and upgrading the front. Compliments of Haro's diligent salvage operation. Any suggestions on bushings? I found the harder gm bushings, but was curious if anybody makes a good urethane set. Or if the factory ones are good enough until i update the shocks...
- willwren
- Retired Admin
Re: Sway Bar Bushings
Techinfo is your friend. The universal kit I list for the rear of the 92-99 will give you the bushings you want.
Silver03Se
i failed to mention i have an 03.. Will those interchange with my year?
- willwren
- Retired Admin
Your profile told me what you have. As well as your username.
Yes, as I said, the rear bushing kit I list for the 92-99 in that Techinfo article will give you the bushings you need. You can get the correct front kit by simply measuring the length and going to autozone, and pick the one off the shelf you need.
IIRC when we installed these on Pdad's 2k SSEi a few years back, we had to cut the Energy Suspension spacer a little shorter to match OEM.
