rough idle
spydog
Year and Trim: 1998 and 1999 bonnavelle SLE 1994 bonnavelle SSE
rough idle
Post by spydog »
hi guys i have a 1999 SLE and at idle my rpms go up and down a bit maby between 700 rpm to 1000rpms anny sugestion on what i can look for or what may be my problem?
1999 SLE 98,xxx miles
1998 SLE 178,xxx miles sold for $1,400
1994 SSE 289,xxx miles
1993 SSEI 324,xxx miles sold for $500
2002 Trans Am 32,xxx miles
1998 silverado waldoch conversion 122,xxx miles SOLD
1979 Trans Am 68,xxx miles
2000 GMC crew cab long box dually 82xxx miles
charliemax
Year and Trim: (Still have 3) 1995 SE - 1996 SSE - 1998 SSEI
Re: rough idle
Post by charliemax »
Have you been working around the engine any? One possibility is you have a small vacuum leak.
spydog
Re: rough idle
Post by spydog »
i replaced the upper intake this last summer about 4K ago
spydog
Re: rough idle
Post by spydog »
i pulled the car in the garage nast light and i noticed sone green coolent on the lower intake manifold i am thinking i didnt get the upper plastick intake tight enough when i replaced it this last summer what do you guys think i couldnt get to all the bolts because of the fule rail but the ones i could get to i could almost turn 1 full turn
bill buttermore
Re: rough idle
Post by bill buttermore »
spydog wrote:... i couldnt get to all the bolts because of the fule rail but the ones i could get to i could almost turn 1 full turn
That would be a problem. Loose bolts could allow a vacuum leak causing or contributing to the erratic idle, and on the throttle body end, if the UIM bolts are not uniformly tightened, you could see a coolant leak as a result. It is not that difficult to lift the fuel rail to gain access to the bolts. Read through this Techinfo procedure to see how. You might also want to consider changing out the LIM gaskets and getting rid of DEX if you have not already done so. Read this Techinfo article to understand why.
Some other causes of erratic idle include: idle air control valve, dirty throttle body, and faulty throttle position sensor. But the most common and likely cause is a vacuum leak.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
spydog
Re: rough idle
Post by spydog »
ok thaks for tjhe sugestions i will pull the car in the shop some time with in the next week and pull the fule rail and tighten the upper intake bolts do u have a torque spec on th bolts?
bill buttermore
Re: rough idle
spydog wrote:ok thaks for tjhe sugestions i will pull the car in the shop some time with in the next week and pull the fule rail and tighten the upper intake bolts do u have a torque spec on th bolts?
look in the articles linked for you above.
spydog
Re: rough idle
Post by spydog »
i removed my fule rail this last weekend and tightened up the upper intale and the rough idle went away allmost all the way i may have to replace the gasket this summer agen
bill buttermore
Re: rough idle
Glad to hear it. Thanks for letting us know.
