Last night I was on the way hoe from a friends house and noticed the blower didnt turn on. After 20 minutes of messing with the controls, I had given up, assuming the motor had gone out. Then in the same fashion as usual, it ramped up and gave my glorious warmth.
So what controls when the motor turns on? Why would it take such a long time.
Delayed Blower Motor Engagement
- yourgrandma
- Year and Trim: '02 SSEi
ChilinMichael
- Posts like a Northstar
- Year and Trim: 2004 Volvo S60
Re: Delayed Blower Motor Engagement
Sounds more to me like the blower motor is failing...although a loose connection can cause this....next time you notice it NOT working, leave the controls on and tap the blower motor a few times to see if that makes it turn on. If it does, blower motor needs to be replaced...
windshield_time
- Year and Trim: 2003 SE 98571 on 5/23/08
The design is, IMO, bad. You can pull the motor, disasemble and clean it and it should work for quite awhile. I have pics of when I did this myself I just haven't posted them. (I'M LAZY). You would need to purchase electric motor cleaner in a spray can. I think there a written instructions on the site somewhere.
I've been to jail in 12 different states !
For Sale at this time.
zuluhead
- SSEi Member
- Year and Trim: 2000 SSEi
Do you have the auto climate controls on your SSEi? On my SSEi the blower doesn't come on until the engine temp is around 150* or so. Normally it hits that within a few minutes, but if your thermostat is stuck open it could take a long time to get there, especially if you live North of the Mason-Dixon. Keep an eye on the temp gauge next time you notice it happening.
2000 Bonneville - SSEI
- yourgrandma
I was watching the temp gauge eagerly awaiting the turn on point. I wouldnt think the motor is failing, either because it ramped up, just as normal. Is there a temp sensor that is specific to the climate controls that could be sending erronious readings to the CC computer?
Mine did that when it was failing. All of the sudden it would come on, esp. if I had just hit a bump. Once it gets going, it goes, but if it's worn out it can't get going, but once its going, it can keep itself going.
