Infrequent fuel leak
azu
Year and Trim: 03 SE
Post by azu »
It is leaking at the quick connect feeding the fuel rail (In coming fuel). Only leaks maybe once every week or two but enough for concern. My question is:
Are the clips a one time use or are they a part of the hose and must be replaced as a whole unit?
13 Chevy Malibu LS 73K
The only dumb question is the one you didn't ask.
Mechanical Mike
Year and Trim: 99 SSEi
Re: Infrequent fuel leak
Post by Mechanical Mike »
The clips are reuseable. I think there's an O ring in the hose that can be replaced. I'll go check the FSM.
2006 Chevy Monte Carlo SS
bonnie02rkt
Year and Trim: 2002 se
Post by bonnie02rkt »
Hey I had that same issue about a month ago; yea there is a small o-ring in there and mine was smashed up pretty bad causing a pool of gas on the manifold. I freaked when I saw it; I was not lookin for any engine fire to break out!
david
2002se/20"msr wheels w/nitto555/ drilled&slotted baer rotors/ delco plugs and wires/monroe struts& shocks/180 tstat/ new allum. L.I.M./gutted airboxw/k&n /pioner deck/kicker 6.5 doors& 12" cvr's w/2000w amp/ nxt to come(intense pcm/magna cat back)
1fatcat
Year and Trim: before cars
Post by 1fatcat »
There are actually two o-rings in there.
Mechanical Mike
Where did you get the O rings?
azu
Post by azu »
Mechanical Mike wrote:Where did you get the O rings?
I want to know also. I could get some from a JY.
1fatcat
Post by 1fatcat »
The only place I know of is to buy a replacement end for the fuel line (I know Oreilly's sells them, maybe Napa too?) and you can either replace the whole end section or rob the o-rings from the new end and just replace the o-rings. Replacing the end section usually involves warming a plastic fuel line and forcing it over a barbed fitting and it can get tricky.
