Thanks guys! It's been a great car to me, so I try to return the favor whenever I can. This was the car that converted me to GM from Honda, and it's now surpassed the miles that my Honda had...with a ton fewer problems, and no creaks or rattles. Well, except from the strut mounts up front, which is on my agenda. Soon, I hope.
crash93ssei wrote:What process did you use for the headlights?
For the most part I used what is in this kit:
...which can be picked up at Wal-Mart, in the automotive lighting section.
The secret is to sand, and sand...and sand. It says for 3 minutes but I sanded lightly with both of the supplied grits for a lot longer than that. Just kept it wet and sanded while I watched TV. After that I used Plast-x polish twice to remove the sanding haze, then buffed to remove the residue. Then I used the included CV #1 (which is like Plast-x), buffed, rinsed with water and then dried and buffed again, and then used their included CV #2 which is something like a sealant, and it also removes all remaining haze and makes the headlights completely clear. Really good stuff, and it will work on even the worst of headlights. The worse they are, the more sanding you have to do.
SLEighride03 wrote:how did you get it so that this white residue didn't show up all over the various parts (alternator, etc) after washing her down?
The WD-40 helped with that a lot. Since it doesn't harm electronics, I was able to spray it onto places that I wasn't able to spray with the degreaser, like the alternator and coil packs so I could wipe them down and clean them too. It also got rid of the weird little spots that come from the degreaser drying on stuff.
wake wrote:dan i really like what youve done with the engine bay especially the valve covers
Thanks, that was actually one of the most difficult things I've ever done, lol. I did it way back in the day before I knew a whole lot about how my engine was put together. I did both sides with a small brush without removing the valve covers...or anything else...from the engine. Didn't use masking tape either. Not sure why, but I didn't. It took a very long time, a very steady hand, and a very painful back. But it turned out nice and has lasted well.
Soon I'm going to wash and wax it. It needs both. The water is still beading but it's been long enough that I'm thinking about it a lot. It's raining right now and it's supposed to rain tomorrow too so maybe I can do that Thursday.
