A couple Problems on my 93 ssei
epicpwn
Year and Trim: 1993 bonneville ssei
Post by epicpwn »
well i got my bonnie started today and the exhuast right after the cat get red hot all most orange and i know when my freind had the car before me when you turned the car would make a bong sound hope some one can help me out thanks for your time
DD - Cobalt LT
Project Cars - 93 Bonneville SSEI and a 58 Stubebaker Transtar
alec_b
Year and Trim: 1996 SSEi, Bright White, Medium Teal, 197k
Re: A couple Problems on my 93 ssei
Post by alec_b »
It's running very rich if the cat is getting that hot, meaning it's not firing correctly. How does it run? How long has it been sitting without running?
Also, to make it easier for us to help you, try using punctuation and complete sentences. It just helps make it a little easier to understand in type.
Thanks and welcome!
Mods: Clear corners, gutted airbox, Alpine CDA-9886. Plans: 4x SensaTracs, high-flow, FM 80, 3.5 pulley, and for gods sake some good rubber.
Could be a bad O2 sensor, or a bad cat. Or both.
epicpwn
Post by epicpwn »
it seems like its runing ok its been sitting all most a year i think maybe less. well if its running rich how could i change it? also the o2 sensor is new.
DD - Cobalt LT
Give the stuff on this list a good look over. Could be part of your issue, especially plugs and wires. Then we can go from there.
Brand Suggestions are in the parentheses.
  • 1987-2005 Bonneville / Buick 3800 Maintenance List
    Run Seafoam through gasoline and intake every 5,000 miles. One pint of Seafoam in a half tank of fuel is a good mix. The intake is optional, but recommended.
    Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease recommended)
    PCV Valve Every 30k
    Fuel Filter Every 15-25k (Purolator, AC Delco, WIX)
    Spark Plugs Every 30-50k (NGK TR55 or Autolite 605) (Never Bosch)
    Oil & Filter Every 5-6k or Every 6 months (Mobil1 or Amsoil)(Mobil1, Purolator PureONE, Amsoil EaO or WIX) (Never Fram) viewtopic.php?f=45&t=214
    *Conventional Oil Every 3k/3 months(Pennzoil with a WIX (Napa), Delco or Purolator filter)
    Transmission Flush Every 15-20k (Always make sure filter is changed when flushed)
    Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Green Coolant Only) (Never Dexcool)
    Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only)
    *Special Considerations*
    All 3800s, LG3, LN3, L27, L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
    Rev. 11/21/09 By 00Beast
Roadrunner
Year and Trim: 03SSEI, 00SSEI, 92SE(sold), 93SSE/SC, 87GTA, 01TA
Post by Roadrunner »
If your car was sitting for a long time, the fuel could have gotten nasty - possibly causing an injector to stick.
Otherwise, I once had a similar problem when one of my ignition coils was going bad and giving weak spark. Was scratching my head for a while until the coil got bad enough to positively confirm that it was the problem.
1fatcat
Year and Trim: before cars
Post by 1fatcat »
Does the car have any power and does it shift properly? If not, the catalytic converter may be restricted. If it is, you would have to replace it.
epicpwn
Post by epicpwn »
i drove it around the farm today it shifts good has power but its smells like its running rich the exhuast smells like gas. All the spark plugs and spark plug wires and a new o2 sensor and all the coil packs are new. the exhuast is new when they did it they said the cat look good so they didnt replace it and yes its been siting without running
DD - Cobalt LT
1fatcat
Post by 1fatcat »
Try some fresh premium gas first and see what happens.
epicpwn
Post by epicpwn »
well i was looking for more about why the cat would get so hot and one was that the motor is dumping raw fual in to the cat but why idk
DD - Cobalt LT
1fatcat
Post by 1fatcat »
The cat's job is to get hot, very hot. The honeycomb material inside is supposed to store heat from the exhaust. Once the cat is fully warmed up, it will be hot enough to burn any unburned fuel that may have left the engine. This is done for emission reasons, because unburned fuel is harmful to the envuironment. If the cat has to burn too much unburned fuel from the engine, it can get red hot. If your gas is old it may not be burning completely, leaving a lot for the converter to take care of. So, some fresh fuel may be all you need? There are lost of reasons an engine can run too rich, but you should start with fresh fuel so the engine CAN burn it better, then go from there if it is still getting too hot.
epicpwn
Post by epicpwn »
good point i wish i knew more about engines myself but im more on the body man side thanks for the help ill me messing with the car more today
DD - Cobalt LT
epicpwn
Post by epicpwn »
also would a partly cut spark plug wire do the same thing to the cat?
DD - Cobalt LT
92BonneSE
Year and Trim: 2008 Aura XE
Post by 92BonneSE »
If the spark plug wire is cut, it could not be giving that cylinder any spark. That could be causing it, either way I would replace all the plug and wires if there is a cut in one of the wires.
2017 Cruze RS
2008 Aura - Totaled
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
epicpwn
Post by epicpwn »
well i replace all of the spark plug wires sounds better but its still getting hot but i did find a good place to get a cat zzp $65 bucks for a magna flow cat
DD - Cobalt LT
epicpwn
Post by epicpwn »
i fixed the cat problem 2 spark plug wires were mixed up so who ever did them befor eme *fook* it up so thats fixed now i need to look at the suspension
DD - Cobalt LT
92BonneSE
Post by 92BonneSE »
Whats wrong with the suspension?
2017 Cruze RS
2008 Aura - Totaled
1998 Bonneville SE
1992 Bonneville SE
epicpwn
Post by epicpwn »
it makes a poping noise when you run it to the right and it pulls right when you turn left i have no idea what it is i looked at it today and everything seemed fine just the top suspsion plat was rusted a bit so idk
DD - Cobalt LT
