Fuel line question
Blownville
Fuel line question
Post by Blownville »
I am looking at a 95 SE that the people are selling as a parts car but it does run and drive and they are only down the street. The biggest issue with me is the fact that one of the plastic fuel lines is cracked by the intake. How do you repair these lines? It looks like it goes into the firewall? Is there a way to fix without replacing these? Thanks.
2003 SLE 145K PLIM, Tune, FWI, 180stat, Magnaflow cat and mufflers
1968 Galaxie Country Sedan Wagon 390/C6/2.75
dirtracr95
Year and Trim: 1988 and 1987 Buick Lesabre T-Type
Re: Fuel line question
Post by dirtracr95 »
I believe it goes down and connects to a metal line they should be easy to replace they are quick disconnect. i swapped an engine on a 95 SE. Alot of 95 L36 stuff is unique because it is OBD1.5
~~~Freddy~~~ Wyotech Graduate, Future RCSAMS student
Pandora 1988 Lesabre T-Type 259000 miles
Darlington 1987 Lesabre T-Type 115000 miles
Cream Puff 1988 Lesabre T-Type 194500 miles
There are special fuel line repair kits for that style, IIRC. You can get them at parts stores.
sonoma_zr2
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
Post by sonoma_zr2 »
in a pinch, take a piece of fuel hose and slit/tie wrap it.
Blownville
sonoma_zr2 wrote:in a pinch, take a piece of fuel hose and slit/tie wrap it.
Thats what I was planning to do.
Thanks all for the help. I will check the auto parts store and see if they have a repair kit.
sandrock
Post by sandrock »
The entire repair kit is very cost-prohibitive. Trust me. What I ended up doing to mine was I got rid of all the hard plastic lines right to where they meet the metal lines (which will be right behind the passenger wheel well), fabbed up some steel lines, and used high-pressure rubber fuel line and injection clamps to connect everything together.
Now, there are replacement nylon fuel lines with the connector already in place, with a brass barb to splice the new line into the old nylon line. The only problem with these is that the factory nylon lines are double-walled, and have already shrunk to the point where they can't shrink anymore. Putting the barb on the new line is easy...just heat it with a heat gun, and insert with some brute force. Putting the barb on the existing line...not nearly as easy. The proper repair job would be to run all new nylon line to the steel line, but that would involve having to take the steel line out of the car to make the union possible. No matter which way you go, it won't be as simple as it should be.
Blownville
Hmmm, well I may just have to patch it and leave it to someone else. I am really only interested in the tires on the car for my 93. If I can get the car cheap enough then I would just resell it with the line needing to be fixed maybe even throw in the fix it kit. Thanks for the info.
