SES Light
Aviator327
Year and Trim: 2002 Bonneville SLE
SES Light
Post by Aviator327 »
The Service Engine Soon light came on yesterday morning. Took it to the dealer this morning and the code that came up was PO420 (Catalytic converter). They didn't have one in stock so it is being shipped from Lansing, MI. just curious if this is a common issue for the Bonneville? Current milage is 51,000mi.
THE AVIATOR'S BONNE
2002 SLE, Purchased 10-18-07. 35,341 miles
Silverstars, 9005ST,9006ST
1fatcat
Year and Trim: before cars
Re: SES Light
Post by 1fatcat »
It is, but alot of times the converter fails because of a rich running condition. Take a real good look at your fuel pressure regulator. Also, cleaning the MAF sensor never hurts.
Re: SES Light
Make sure this list is up to date.
Brand Suggestions are in the parentheses.
  • 1987-2005 Bonneville / Buick 3800 Maintenance List
    Run Seafoam through gasoline and intake every 5,000 miles. One pint of Seafoam in a half tank of fuel is a good mix. The intake is optional, but recommended.
    Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease recommended)
    PCV Valve Every 30k
    Fuel Filter Every 15-25k (Purolator, AC Delco, WIX)
    Spark Plugs Every 30-50k (NGK TR55 or Autolite 605) (Never Bosch)
    Oil & Filter Every 5-6k or Every 6 months (Mobil1 or Amsoil)(Mobil1, Purolator PureONE, Amsoil EaO or WIX) (Never Fram) viewtopic.php?f=45&t=214
    *Conventional Oil Every 3k/3 months(Pennzoil with a WIX (Napa), Delco or Purolator filter)
    Transmission Flush Every 15-20k (Always make sure filter is changed when flushed)
    Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Green Coolant Only) (Never Dexcool)
    Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only)
    *Special Considerations*
    All 3800s, LG3, LN3, L27, L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
1fatcat
Re: SES Light
Post by 1fatcat »
Not trying to nit-pick, but some of the things on your list seem to be recommended a little too soon. For example:
Air filter: a paper air filter usually lasts about 40,000+ miles under normal driving conditions.
PCV: a pcv will usually last about 80,000+ miles
MAF cleaning: depends on your air filter...an oiled filter will require more frequent MAF cleaning
Fuel filter: about 50,000+ miles
Spark plugs: around 50,000-90,000 miles depending on if they are platinum or not
Plug wires: 80,000-100,000+miles
Transmission fluids: I ain't touching that with a 10 foot pole!
Coolant: 50,000+ miles
Oxygen sensor: only when it fails
Drive belt: when it is badly cracked
Supercharger oil: 100,000+ miles
OK, bring on the flame thrower!
bonnevillain
Re: SES Light
Post by bonnevillain »
I agree some of those things can last a lot longer than listed, but they are also pretty cheap (or free!), and it certainly can't hurt. I also disagree with only changing oxygen sensors when they fail.. they do go "sorta bad" before they throw a code, and mileage usually suffers.
Re: SES Light
The mileages may not be 100% accurate, but it's better to be safe than sorry.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: SES Light
Post by 01bonneSC »
00Beast wrote:The mileages may not be 100% accurate, but it's better to be safe than sorry.
x2 its called prevenative maintanance, and ur car will run better, for longer when u change things before they start reaching the end of their life
Aviator327
Re: SES Light
Thanks for the feedback guys.
THE AVIATOR'S BONNE
bonnie02rkt
Year and Trim: 2002 se
Re: SES Light
Post by bonnie02rkt »
I had the same ongoin problem for about a year and a half and could never get any help with the issue. I replaced the cat first and about 600 miles later the same code came up... shortly after i replace sensor after sensor and could never get rid of the code. I even replaced the ECU! Then I finally said the hell with it and got the ecu from intense and got the code deleted! I assume I never really fixed the problem!
david
2002se/20"msr wheels w/nitto555/ drilled&slotted baer rotors/ delco plugs and wires/monroe struts& shocks/180 tstat/ new allum. L.I.M./gutted airboxw/k&n /pioner deck/kicker 6.5 doors& 12" cvr's w/2000w amp/ nxt to come(intense pcm/magna cat back)
bonnevillain
Re: SES Light
the rear 02 going bad could probably cause this also.
01bonneSC
89 SkiDoo
Re: SES Light
Post by 01bonneSC »
bonnevillain wrote:the rear 02 going bad could probably cause this also.
x2! beat me to it!
Yeah if the catalyst sensor isnt working properly, then it would think the cat is bad.
Aviator327
Re: SES Light
The dealership ordered it on Monday and hasn't got here yet. They said the cat converter had to be shipped by truck because of its length. He said the converter goes all the way to the back and ties into the exhaust system.
THE AVIATOR'S BONNE
Re: SES Light
Uh, no. The converter is about a foot in length. Would they have ordered the resonator by mistake??
Aviator327
Re: SES Light
Who knows. That's what the service rep told me yesterday. I thought the converter was short.
THE AVIATOR'S BONNE
01bonneSC
89 SkiDoo
Re: SES Light
Post by 01bonneSC »
Shoulda picked up this and just headed to the exhause shop...
http://www.3800performance.com/Merchant ... t_Count=27
1fatcat
Re: SES Light
Post by 1fatcat »
Cats are covered under factory warranty for 8 years or 80,000 miles. They SHOULD have ordered you the factory replacement cat, which is pretty long on your car. It may even go all the way to the tail pipe?
Re: SES Light
Its possible that they had to order a complete exhaust system. The OEM system doesn't have replaceable joints.
bonnevillain
Re: SES Light
1fatcat wrote:Cats are covered under factory warranty for 8 years or 80,000 miles. They SHOULD have ordered you the factory replacement cat, which is pretty long on your car. It may even go all the way to the tail pipe?
no. The factory cat is only about a foot long.
I think Haro may be right though, They would have to cut it out and weld in a new one, which they may not want to do.
white06lacrossecxs
Year and Trim: 2006 Buick Lacrosse CXS
Re: SES Light
Post by white06lacrossecxs »
When the cat on my park avenue went bad the entire exhaust from the cat back had to be ordered because it is ordered as one piece. We had an aftermarket one installed instead. The dealer quoted $600 for the part.
1fatcat
Re: SES Light
Post by 1fatcat »
I have worked for a few dealers and we never did a weld in replacement if it was covered under warranty. It got the same assembly that came with it new.
