Antennae Mast Fix
jdronzek
Year and Trim: 1999 Oldsmobile 88 LS
Antennae Mast Fix
Post by jdronzek »
I thought i'd post how to do this.. There was a guy asking about this and I told him I'd post a tutorial. Enjoy.
Antennae not going up and down? Heres how to do a simple fix. This was done on a 93 Buick Lesabre (friends car.)
Most are the same.
Step 1.
Dismount antennae mast. (Sorry no pic. Too easy.)
Step 2.
Take off all the metal clips and screw holding together the thing. There are some type of rivet. Punch those off.
Step 3.
Take the motor apart. Heres what it should look like:
Step 4.
Most likely, the sturdy yet fragile plastic covered metal wire is the culprit in this situation. Take a look.
Either you do like me and melt the thing, or go buy a new for probably 50 bucks. Cheap is good. Free is better.
I melted the thing together like so.
Step 5.
Next take a simple razor blade and cut off the huge boulders (especially if you dont know how to melt together plastic.) Make sure its somewhat smooth. Dont shave off too much or it will be too fragile and crack in the gear.
Step 6.
Your mast should look like this:
Step 7.
Here is the gear. Make sure your cable winds freely in and out of the gear. That is vital.
Step 8.
Alright, great. Now put it all back together and you're back to wonderful antennae automation!
sterdeus
Year and Trim: 95 SSEi RIP (401,000 km)
Re: Antennae Mast Fix
Post by sterdeus »
Great tutorial. I had to do the same steps a few months ago because my antennae was only going up half way. I didnt have to melt a new plastic "fishing" line in because I couldnt find what the problem was. I just put it back together and it worked again.
Bump for a good tutorial.
95 SSEi Green Machine RIP
401,000 km to the end. Still ran but other problems send her to the recyclers.
Recent fixes: Supercharger coupler, AC compressor (x2), bumper covers (front and rear), antennae. Finally found the air compressor kit at the autoyard!
Small Business Internet Marketing Services for East York / Danforth (Toronto)
bobfather99
Year and Trim: 1995 White Bonneville SE
Post by bobfather99 »
Ive thought about tearing mine down and figuring out why its messed up, but unplugging it stopped it from running all the time, so its stuck in the up position forever. I can live with it. :beerchug:
188340 Miles as of 06/07/10, still running.........
LIM/UIM Work done 4/23/07 at 145000 miles...
jdronzek
Post by jdronzek »
bobfather99 wrote:Ive thought about tearing mine down and figuring out why its messed up, but unplugging it stopped it from running all the time, so its stuck in the up position forever. I can live with it. :beerchug:
Its stick up because its so filthy inside. believe me. When we took his apart it was like dripping with sludge. (Hence me saying DO NOT PUT LUBRICANT AND SPRAYS ON THE MAST)
Bob Dillon
Post by Bob Dillon »
I used the $28 permanent fix. I trashed the power antenna and bought the fixed one from the dealer. Better reception, too.
jdronzek
Post by jdronzek »
Well hey, watch whenever the children across the street hate you and bend up your antennae. I've seen it happen.
But then it bends right back, unless they break it off. With the power antenna, they could break/bend it a whole lot easier.
jdronzek
Post by jdronzek »
Not while its in retracted! :booty:
adinini
Year and Trim: 99' SLE
Post by adinini »
My antenna was suck-ass too...so I bought a satellite receiver and unplugged the antenna.
1fatcat
Year and Trim: before cars
Post by 1fatcat »
A local parts store here sells a replacement mast. Someone want to send me their broken assembly? I'll fix it and send it back for $10 over the actual cost of parts & shipping. I think the mast is about $20? I put one in mine over a year ago and it is still working great!
jdronzek
Post by jdronzek »
The local junkyard wanted to charge my friend 45$ for the mast. USED.
spydog
Year and Trim: 1998 and 1999 bonnavelle SLE 1994 bonnavelle SSE
Post by spydog »
i need my antenna fixed.
A local parts store here sells a replacement mast. Someone want to send me their broken assembly? I'll fix it and send it back for $10 over the actual cost of parts & shipping. I think the mast is about $20? I put one in mine over a year ago and it is still working great![/quote]
1999 SLE 98,xxx miles
1998 SLE 178,xxx miles sold for $1,400
1994 SSE 289,xxx miles
1993 SSEI 324,xxx miles sold for $500
2002 Trans Am 32,xxx miles
1998 silverado waldoch conversion 122,xxx miles SOLD
1979 Trans Am 68,xxx miles
2000 GMC crew cab long box dually 82xxx miles
1fatcat
Post by 1fatcat »
spydog wrote:i need my antenna fixed.
If you want me to fix your antenna, send me a PM and I will give you my address. I ask that you ship your antenna assembly along with $30 and a postage paid return shipping label. The $30 covers the cost of the NEW mast and a little labor for my time. I will replace the mast, test the assembly and ship it back to you in 2 days. Obviously the shipping transit time is beyond my control, but I personally will only need your assembly for 2 days.
Maymybonneliveforevr
Year and Trim: 01 Buick Century Limited
10 Toyota Avalon XLS
Post by Maymybonneliveforevr »
That actualiy sounds like a good deal considering new masts are around $20.00 including tax.
Last edited by Maymybonneliveforevr on Sun Sep 06, 2009 4:44 pm, edited 1 time in total.
White93Z34
Year and Trim: 1997 SSE
Post by White93Z34 »
I fixed mine about 2 years ago now, my mast was just bent by the PO going through a car wash with it up. Just had to take it apart and gently work it back straight again. As for lubrication, I used synthetic brake caliper grease to lubricate the gears. Still works great, I also unplug the motor during the winter to help with stress on everything inside.
-Chris
1992 Chevrolet Lumina Z34 3.4L TDC v6, Hydramatic 4T60E
1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
1997 Pontiac Bonneville SSE 3.8L v6, Hydramatic 4T60E
1987 Chevrolet Camaro 5.0L v8, Hydramatic 700R4
Ol' Timer
Year and Trim: 1991 Olds 88
Location: New Jersey - Most of Our Elected Officials Have Not Been Indicted
Post by Ol' Timer »
White93Z34 wrote: I also unplug the motor during the winter to help with stress on everything inside.
:) :) I do the same because moisture seems to get into the works and prevents the shaft from rising during those mornings where the temps are below freezing. It would eventually go up if/when the temps rise in the trunk and warms up the antennae.
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels
2002 Snap Orange Beetle - Auto - Turbo
1991 Dark Garnet Red Oldsmobile 88 - Donated to Science
