Need tip on removing bolt?
pontiac6269
Year and Trim: 2006 Grand Prix Sedan
1998 Olds 88
Post by pontiac6269 »
My 98 Olds 88 has the shuddering when you take of from a stop. I did a search on the forum and found that it is the rear passenger transmission dogbone. How did you remove the bolt that hits the engine cradle? I have the new part to replace.
Thanks,
Eric
1969 Pontiac GTO
1978 Olds Cutlass Supreme
1981 Chevy C20
1985 Chevy K5 Blazer
2001 Ford F350 SC Cab&Chassis Dually
2004 Bonneville SE
2008 Grand Prix
dangrus4060
Year and Trim: NEW 99SSEi
Daughter-97SEw/SLE Opt
98SSEi Wrecked
Re: Need tip on removing bolt?
Post by dangrus4060 »
I found this out when I had to rebuild my motor.
I needed a new dogbone (rubber was squishing out) and ran into the same problem as you. You will need to remove the entire bracket from the rear of the differential cover, then you can remove the bolt. Remember to put the dogbone back onto the bracket before putting the bracket back on the diff. cover. Then you can tighten the thru bolt back up. :bow:
Hope this helps!
Dangrus4060
99 SSEi Galaxy Silver w/Dark Pewter Leather, Bought Aug. '08 w/75,000 mi. Bose Sunroof Michelins 35% Charcoal Tint(max. legal) Gutted Airbox w/K&N Drop-in 180Deg. Drilled Stat. Flushed Dex-Col Castrol Edge 10W30 w/PureOne Dual Chromed-Stainless Exhaust Tips Avital - Avistart 5303 Remote Start w/Security SilverStar Ultra's HL Rebuilt Motor w/New Crank & L32 Powdered Metal Connecting Rods
Daughter's 97 SE w/SLE White w/Dark Pewter Leather Bought Apr '06 w/153,000 mi. AM/FM/CD w/ 7-Band EQ Gutted Airbox w/K&N Drop-in
180Deg. Drilled Stat. Flushed Dex-Col Valvoline Max Life 10W40 w/Pure One Avital - Avistart 4300 Remote Start w/Security
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Is that shuddering more pronounced when you give it a lot of throttle from a standing start? I think my car has the same issue, but I'm not sure.
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
LeSabre in Buffalo wrote:Is that shuddering more pronounced when you give it a lot of throttle from a standing start? I think my car has the same issue, but I'm not sure.
I don't believe so -there is a bulletin out for this issue, which is a shift solenoid not down-shifting from 3rd until you pull away from the stop -what you are feelin is the transmission stumbling (or slamming) down into 2nd gear, then 1st.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
pontiac6269
1998 Olds 88
Yes, can feel it at half throttle and gets worse from there.
Thanks,
Eric
1969 Pontiac GTO
1981 Chevy C20
2004 Bonneville SE
2008 Grand Prix
