Turn signals stay on
aCiD
Year and Trim: 98 SSEi
Post by aCiD »
So we had an issue with the flasher unit like 6 months ago, replaced it, and all was fine.
Figured it died again recently, so I got a new good one today, but hasn't fixed it, what happens is you set your turn signal to left (or right, or hazards), and the light just stay on.
The turn signal fuse is fine also. What else would it be?
thanks.
1999 Mustang GT - 600rwhp 520rwtq
2004 G35 M6
2002 Jeep Grand Cherokee Overland Edition
1998 SSEi
1997 SSEi - wrecked
1995 SE - blew up 3 3800s, gave up
spoiledred94
Re: Turn signals stay on
Post by spoiledred94 »
A quick Idunno, That problem has always been the flasher in my 94SE. Check that you are getting solid connections in your circuit. The wiring diagram is in the Chilton manual. It's a simple circuit for my car probably yours too. You should be able to locate the bad connection with that. Or it may be on the outside chance a bad flasher can, again.
great car. Wrecked
Burnt Bonny.
aCiD
Post by aCiD »
A mechanic friend just said it's likely a bad contact on the indicator switch in the steering column, and that it was a terribly difficult job... :(
Anyone done that repair before?
2004 G35 M6
1998 SSEi
1997 SSEi - wrecked
jdronzek
Year and Trim: 1999 Oldsmobile 88 LS
Post by jdronzek »
yes. bad contact. Ever see someones flashers going down the road and they blink extremely fast (faster than normal)? They have a bad contact. Check that. Its most likely the problem.
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
jdronzek wrote:Ever see someones flashers going down the road and they blink extremely fast (faster than normal)? They have a bad contact.
That's a burnt out bulb. Different animal :wink:
edit: Something similar happened on my mom's Nissan, and by some freak incident, after I tried the four-way flashers (which worked fine), the normal signals came back to life and have been good since. Worth a shot? :???:
aCiD
Post by aCiD »
Yea, that's a burnt out bulb, that happens on purpose.
I tried the 4 ways, they did nothing at all.
2004 G35 M6
1998 SSEi
1997 SSEi - wrecked
jdronzek
Post by jdronzek »
Oh really? I didn't know that. ive always been told it was a short or bad connection.
Check all your bulbs looking for burnt filaments inside them. Look for moisture in the lenses and housings.
