How to Mod a 3800 series 2 N/A?
- Night Crawler
- Posts like an L36
- Year and Trim: 2002 Bonneville SE
I was told that with the right mods I could make my series 2 in the SE equal or just a bit better then a stock supercharged series 2.
Can someone give me a list of what has to be done to do this. I would like to get prices ran here to see what it would cost for me to do this. Thanks
Last edited by Night Crawler on Sat Jul 18, 2009 11:16 am, edited 2 times in total.
FWI, converted low beam bulbs into high beam bulbs, 20% tint all around, MSD wires, NDK TR55 plugs, auxiliary line in, scan gauge, custom FloPro/MagnaFlow Cat back exhaust
2002 Bonneville SE
- gonzo4191
- Year and Trim: 91 S10 P/U
97 SSEI- 136k - Location: round lake beach, IL
Re: How to Mod a 3800 series 2 N/A?
well
i see you got the FWI already
most would say that, with a Down Pipe/headers/Power LOG exhaust manifold set up and a hi flow cat for starters..... with more exhaust flow
you can add a cam? or rockers? for more flow both intake and exhaust
nitrous??, ported L67 TB, a tune helps
what is your budget here! and real goals?
- willwren
- Retired Admin
It's going to be rather spendy to achieve the performance of an L67. Clearly state your goals, as a swap might get you there cheaper and easier.
Hitting the same ET on a 1/4 mile track is one thing. But that's still not the same, as the L67 will almost always produce more torque in the low rpm's, and that torque curve remains very flat across the band. This is the major difference between them (due to the blower).
- Night Crawler
- Posts like an L36
no nos. Keeping my car street legal. Is it easy to do a swap or just buy an ssei? And change the body panels? wannna make a sleeper
2002 Bonneville SE
It'd be easier to buy an SSEi. Honestly, I think the SSEi's look better than the SE's, but that's a personal opinion. The bumpers do interchange, however.
- Night Crawler
- Posts like an L36
ya i like the look of the SE's front bumper
2002 Bonneville SE
- gonzo4191
x2, i think if you bought an ssei and swapped over all your bumpers, it would be very nice!!!!
or find a salvage yard l67, plenty of ppl have done that!
viper8907
- Posts like an L36
- Year and Trim: 2000 SSEi
keep in mind if you put an SE rear bumper won't have cut-outs for the dual tips that an SSEi has. They might be low enough that the bumper fits above, but that could be an issue.
-Tom
2003 Silverado Ext. Cab - Charcoal - 128,000 miles - Stock...for now.
2000 SSEi - Gone, but not forgotten.
All depends upon his mechanical skill and what he wants.
- gonzo4191
SE exhuast will botl up to l67viper8907 wrote:keep in mind if you put an SE rear bumper won't have cut-outs for the dual tips that an SSEi has. They might be low enough that the bumper fits above, but that could be an issue.
- Night Crawler
- Posts like an L36
i'd be doing a flowmaster exhaust. And the Se bumper bevels up so the exhaust would fit fine. But i wouldn't be doing the cow bells. Just a dual with dual pipes
2002 Bonneville SE
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Whatever you do, make sure you get tuned to make use of the new parts. Even if it's a canned tune, it's likely going to benefit you, and give you a jumping-off point for further tuning.
If you decide to keep the L36, the folks with ported LIM's are singing their praises.
- gonzo4191
soon david (i think that is your name)
you ill be praising the PLIM
LeSabre in Buffalo
Yep, thanks to Juan!
I'll see how it plays with my canned tune. Hope it leans out the engine, as my fuel trims are on the rich side.
- mylittleblackbird
- Posts like a Northstar
- Year and Trim: 1995 LX(went to the shredder)*sniffle*
1999 SE - Location: Muscatine, IA
home ported heads, a stock cam reground, dyno tune, and a few other oddities put a 97 SE down to 15.3
Last edited by mylittleblackbird on Thu Jul 23, 2009 4:51 pm, edited 1 time in total.
I have a Bonneville, it's white and N/A!
Mod List: Hood and Fender "adjustment" - "Enhanced" A/C compressor clutch - Extra loud PS Pump - Mega sensitive CKPS - Audible Rear Drums - Lowered headliner - Custom stained upholstery - "Brown Devil" weight reduction kit - Low Friction Belt. More to come!
OH2LS
- Year and Trim: 2002 Chevrolet Impala LS
As for an L36, I was running 14.7's with a GT1 cam, 105 springs, PLOG, GMPP exhaust (magnaflow), catless DP, and HV3 insert. Didn't even have a ported LIM. On a warmer day it would run 14.9's. This was all with a ZZP tune. It probably could have improved a little from a custom tune.
"3.8 Liters of twisted steel and sex appeal" -schmidty on NAIOA
I've got an '04 CompG. Got a Gen V and an intake...... so far
LeSabre in Buffalo
That's a good idea of where to go! Kudos for making a speedy N/A 3800!
I've heard good things from the PLIM alone. I'll find out soon enough. If nothing else it's another baseline to start from.
OH2LS
Thanks! It was nice but all the power was up in the high rpms with that combo.
01bonneSC
I ran 14.9 with a FWI, 180tstat, and solid mount with an L67. I say get and L67 and keep your body panels if you want. It will be much less work/moeny than camming, PLIM, and all the other stuff youd have to do to make it a little bit faster than a stock SSEi. Why go N/A when you can S/C?
