speedodometer going crazy
rharper
- Year and Trim: 1999 se
- Archon
Re: speedodometer going crazy
Is there a corresponding increase in engine speed too? Any other symptoms or other problems that could be related?
rharper
she said that the car did not want to go. so no increase in speed . i will have to drive tommrow myself
1fatcat
- Year and Trim: before cars
Wont go like no power or wont move?
rharper
wont go like no power its when she lets off of gas that the speed odometer increases most
- Archon
Is the service engine soon light on? Any codes stored? Especially with the strange symptoms you're reporting, we are going to need a lot more detailed information of everything that is happening at the time in order to be able to help you.
1fatcat
Might be a shot in the dark, but my car acted very strange and very intermittently when the ground block corroded by the underside of the drivers door sill...but thats a 98.
01bonneSC
My car did the same thing in the winter a couple handfulls of times. It actually dropped to 0 mostly. Luckily I had my GPS to tell me how fast I was going. Hasnt done it since early spring. No codes or anything.
rharper
well i drove the car today and it drove normally i probably went 20 miles with no problems still haven't had codes read but someone told me that because the speed odometer is electronic that tells the transmission when to shift that maybe the plug going into trans needs cleaned does this sound right
01bonneSC
I was thinking my speed sensor might be going out.
AIRTEX Part # 5S4633
$20 from RockAuto, guess its on the back of the trans
rharper
thanks 01 bonne sc for your suggestions.
its been hot outside but yesterday i finally got around to looking at it again. i pulled both rear wss plugs and cleaned with contact cleaner and slightly tweaked the plug contacts then put dielectric grease in the plugs then plugged them in. then moved to the front started on the left side(driver side) when i went to unplug the sensor the wires going to the wheel hub parted, hey whats this they were to short to solder back on but i had a old hub from my gmc truck that had the same end on it. after soldering a new end and cleaning, the abs and low traction light went out ,also this cured the speed odometer problem
