94 Bonneville won't go over 40 MPH
94SilverSSEi
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Post by 94SilverSSEi »
Looking at buying this one car and the guy says it has an "acceleration problem" and that the car won't go over 40 MPH anyone know what this could be
Is it going to be an easy fix
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
Re: 94 Bonneville won't go over 40 MPH
Post by Jrs3800 »
Sounds like a clogged cat or fuel pump... But I would really need to look at the car to know for sure
93RedSled-SSE
Year and Trim: 1993 SSE (NA)
Post by 93RedSled-SSE »
Yes, and it could also be running in the "limp home" mode, if it is having an ignition control problem. Often, the engine feels like it is going to "fall out." 94-95 has that goofy OBD vintage (OBD-I with OBD-II connector) that makes it tough to check diagnostic codes without a plug/wiring adapter. My 2 cents, now I have NO sense.
1993 Red SSE - Bone-Stock except for High Perf. (LOL) Power Antenna-Original Owner. Pushing 140K - It's the love of my wife.
'05 Magnum Hemi R/T "Great White" - Classic VW Beetles
2000Silverbullet
Post by 2000Silverbullet »
The 94 went into that same limp home mode when the Throttle position sensor went bad ( actually it had melted ).
94SilverSSEi
68 w/400
94 SSEi
So how much just to get an idea would any of these problems cost?
Clay
2000Silverbullet
The TPS is about $100 and it will take you 10 min to do it yourself.
94SilverSSEi
68 w/400
94 SSEi
What if it is the ignition control problem?
OR limp home mode
how woyld you fix this?
Clay
94SilverSSEi
68 w/400
94 SSEi
Re: 94 Bonneville won't go over 40 MPH UPDATE
Just talked to the guy he said the car just isn't getting any gas and then it won't shift
Sounds like fuel pump and tranny too me
Any other suggestions
Clay
2000Silverbullet
Pull the PCM codes and it will tell you the problem. If you don't have a scanner go to one of the auto shops that does diagnosis for cheap.
Bonneville92V688
Year and Trim: ‘12 Jeep Grand Cherokee Overland Summit
Post by Bonneville92V688 »
2000Silverbullet wrote:The TPS is about $100 and it will take you 10 min to do it yourself.
$100 CDN I assume? Rockauto has the ACDelco for $60.79.
1996 Thunderbird LX - 3.8
94SilverSSEi
68 w/400
94 SSEi
Now he says the car won't run for very long or shift and it has that acceleration problem so anyone's 2 cents would be greatly appreciated
I'm gonna go look at it this Thursday and see what's going on and if I can get it home without towing it
Clay
1fatcat
Year and Trim: before cars
Post by 1fatcat »
There is no way to tell without driving it or some diagnostic information. It sounds like it COULD be a badly plugged catalytic converter?
2000Silverbullet
That happened to our 94. The honeycomb inside the cat broke and turned sideways blocking the flow. It overheated the exhaust manifolds and melted the TPS.
94SilverSSEi
68 w/400
94 SSEi
This sounds like my solution but is there anything that I could do to make it easier to get it home
Because the way he's putting it, it sounds like it would need to be trailered in its current condition
Clay
2000Silverbullet
How far do you have to go to get home?
94SilverSSEi
68 w/400
94 SSEi
Not sure about 40ish miles
Mapquest said 42 mins
The guy said it wasn't driveable very far so I was wondering if there was something I could do to make it run better at least to limp it home
Clay
2000Silverbullet
I drove the 94 like that for about 20 painful miles with hazards flashing letting others pass.
You could loosen off the exhaust flange where the pipe mates with the exhaust manifold to relieve the pressure.........assuming that is what the problem is. :???:
If it's flat and level with minimal stops, you should be OK.
94SilverSSEi
68 w/400
94 SSEi
Thanks
I guess we'll just take it for a test drive and see whats what and see if we think it can make it home if not it will have to be towed
Clay
94SilverSSEi
68 w/400
94 SSEi
How would I go about checking the cat to see if it is any good and where is the tps located and how do you check that
Oh btw I don't have a scanner so I need some help before I get there
Clay
1fatcat
Post by 1fatcat »
You check the cat by measuring the back pressure in the exhaust between the engine and the converter. Anything over 1.5 psi at 1500 rpm is considered restricted. In your case, if the cat is causing the problem, you should be seeing 3 or more psi at 1500 and 20+ psi at WOT. You check it through the front O2 sensor hole or by drilling a 1/8 inch hole in the exhaust pipe just before the converter and measure the pressure comming out with a vacuum/pressure gauge.
The gauge you need is probably $20 for a cheap one. Maybe you would be better off to have an exhaust shop do a back pressure test for you? I would think you could find a shop that would do it for around $30?
