advice on porting L36 throttle body
loud95sse
Year and Trim: 1995 bonneville sse, no S.C.
Post by loud95sse »
Do I take out the whole T. Any other grinding need to be done before polishing other than removeing the T. I'm going to try this and I'm not a pro or anything, so any advice will help. I think I will be OK, if it's as easy as it looks.
I figure I can save 150-$200 to try this myself, then i can spend that $$ on a mod I can't do(maybe rockers or PLOG+PCM). Is doing this going to be as good as a ZZP TB.
Try this for now ,if I succeed, maybe LIM later.
Naturally aspirated 95 bonneville sse. HV3 insert, 9" k+N cold air intake, Hi-flow muff, new metallic paint, 16" chrome rims, tinted tails.
I love Alpine. Alpine cd player, 15" alpine type R w/ alpine mrd-m1005 amp. more to come.
Comeing soon: hi-flow TB, PCM, maybe rockers.
its840
Year and Trim: 2 wheels and 2 pedals... much cheaper that way...
Re: advice on porting L36 throttle body
Post by its840 »
not doubting your abilities at all by any means.. but i would suggest doing an exchange for an expertly done one. less headache and you know its done right.. and you also dont have to risk messing it up..
just my 2 cents..
but if you have a few laying around.. by all means give it a try..
loud95sse
Post by loud95sse »
Pretty much just like this shows right. This was for L67, but I get it.smooth out the edges left from cutting out the T, then buff. Am I missing anything?
http://www.clubgm.com/?name=98tbporting
95naSTA
Post by 95naSTA »
You should start off with a L67 TB first IMO to get the larger TB bore.
Here is what I did to mine.
Keep in mind you're going to have to tune upon install since the MAF will be reading the incoming air differently.
gmtuners.com can do that for you.
willwren
Post by willwren »
I agree you're starting with the wrong TB. I've ported a couple by that method and I can tell you that you'll likely run into MAF calibration issues. Besides, the post isn't as much of a restriction as you might think. The primary restriction is the throttle plate/bore.
This is also somewhat of a case of putting the cart before the horse. Without valvetrain mods to increase flow, this isn't going to net you what you think it might.
loud95sse
Post by loud95sse »
so it may be a waste of time to mess with l36 TB. the L67 seems like a lot more work. I don't have a lot of money and I was hopeing to do A free mod here.
willwren
Post by willwren »
You're just not going to get what you want out of it without tuning and supporting mods. I'd say put this on the back burner for awhile, then you can source a spare to begin working on. It'll be ready when you and your car are.
Allmachtige
Year and Trim: 2009 G8 GT
Post by Allmachtige »
I don't want to hijack this thread, but would I benefit from a bored TB? I always considered it a mod not worth the investment so I never put much thought into it.
2009 G8 GT - White Hot
415/391
loud95sse
Post by loud95sse »
You are right, I will wait untill I have my pcm tuned. In the meantime I will get a used one and work on it. Does the zzp TB have a larger butterfly than the stock. I notice it says bored from 65mm to 68mm. That is probably achieved by using sand paper around the entire inside.
Here is one on porting the l36 TB once I do do it.http://www.mainstreamtopics.com/forums/ ... topic=3313
I sure wish I could afford rockers.
willwren
Post by willwren »
I can assure you that nobody modifies TB's with sandpaper.
