Carpet cleaning questions
airdvr1227
- SSE Member
I don't have a machine. What are you guys using to get them good and clean?
- yourgrandma
- Year and Trim: '02 SSEi
Re: Carpet cleaning questions
Do you have a shop vac?
Just use a hot mixture of water and your choice of carpet cleaner. Agitate and suck as much of it out as practical with the shop vac. Repeat as needed.
Heres a good one:
http://autopia.org/forum/car-detailing/ ... tilez.html
Heres a good one:
ChilinMichael
- Posts like a Northstar
- Year and Trim: 2004 Volvo S60
Meguiar's used to have an amazing QuikOut /w Bissell technology if you can find it, their new one for all Upholstery and carpet seems to work as well from what I've seen (myself), but I haven't really tested it out yet.
93 SSE 4 ME
- Year and Trim: 2005 SLE
Vacuum the carpets/upholstery as best as you possibly can. Remove all the loose stuff that is there. Get a bunch of clean towels together. Mix up some laundry detergent and Oxi-Clean in a bucket with hot water. Don't use alot of detergent, or you'll never get all the soap out of the carpets/upholstery. Get a second bucket with just hot water. Use a towel dipped in the detergent bucket to scrub the surfaces you want to clean, then go over it with a towel dipped in the clear water to get the soap residue out. Go over it until you're satisfied. Go over the area a final time with a dry towel. Vac it when you're finished.
Mark
Mark
'05 Bonneville SLE Intense FWI & PCM, Wood Dash Kit, Chrome Valve Stem Caps!
'14 Silverado LTZ
'08 Acura TL
'05 VW Passat GLS
'14 Silverado LTZ
'08 Acura TL
'05 VW Passat GLS
- ptrfair
- Year and Trim: 2007 Impala SS
1997 LeSabre Limited - Location: Langhorne, Pa
i saw this site before....i have access to the little green ( if my mom lets me use it one day)...would that really produce better results than the link suggests? Looks too good to be true, my upholstry is filthyyourgrandma wrote:Do you have a shop vac?
Heres a good one:
2007 Impala SS - 30k 5.3L V8
1997 LeSabre Limited - 115k
Gone but never forgotten:
2001 Bonneville SE
1992 Bonneville SE
screwstonjay713
- Year and Trim: 2003 Bonneville SE
The only thing I use is the regular shop vac. But I vacuum my car out at least twice a week so it never gets dirty enough too use all those special cleaners. Occasianly I will use the household arm and hammer carpet cleaner on the mats but that's about it.
2003 bonneville SE "Tha maroon monsta"- Blacked out tail lights..20inch gitano blades..7.5inch jensen headunit..2 kicker cvrs..2000watt boss amp..clear corner headlights..Red interior lighting..More to come...
http://www.cardomain.com/ride/3160291
myspace.com/screwstonjay
